How do I install this on Mac Big Sur 11.4 ?
2021-07-14 8:25 AM
I download the package onto my Mac in the Download folder.
I open a terminal and navigate to the Download/en folder.
I execute the command "./SetupSTM32CubeProgrammer-2.7.0.app/Contents/MacOs/SetupSTM32CubeProgrammer-2_7_0_maco"
I receive a popup window saying “SetupSTM32CubeProgrammer-2.7.0.app�? cannot be opened because the developer cannot be verified." Move to trash or cancel.
What am I doing wrong?
STM32CubeProgrammer
2021-07-16 3:25 AM
Hi LHarm.1
There is some tips in CubeProgrammer user manual to installl it on MAC:
- Make sure you have administrator rights, then double-click SetupSTM32CubeProgrammermacos application file to launch the installation wizard.
- In case of error, try one of the following fixes: $sudo xattr -cr ~/SetupSTM32CubeProgrammer-macos.app launch the .exe file with the command sudo java -jar SetupSTM32CubeProgrammer-2.7.0.exe.
can you please try them and tell me if it is Ok?
Houda
2021-07-16 11:38 AM
The app installed, but does not run.
