DFU Firmware lost
cloud_liu
My MCU is STM32F746ZG. When I want to use DFU to upgrade my board by STM32CubeProgrammer, It show "No DFU detected" in the port list. And I use "zadig" to try install DUF driver, it cannot find any STM DUF device, too.
Do my DFU firmware lost in my MCU? If can I download DFU firmware to program it by ST-Link?
Cloud
Please contact maker of this board (or their community) - they will be glad to help. According to the board image, it has a USB connector. Maybe need to put some jumper etc.
4 REPLIES 4
Pavel A.
Evangelist III
The "system bootloader" implements DFU, it cannot get lost and you don't need to program it.
Just connect the USB pins of the board correctly and use a good USB cable. If the board is not visible on Windows side in the device manager (even as unknown device) - you've failed to connect it correctly. Try again.
Ok, I will contact the maker, thanks for help.
