YBAYR.1
Why do I need to debug my project every time to make it stm32 work?
  • February 24, 2023
  • 3 replies
  • 1839 views
What is the reason why the system does not work when I turn it off after disconnecting it from the computer?
For the system to work, I need to connect it to the computer, then when I debug, it works without any problems.
Tesla DeLorean
Guru
February 24, 2023
You've built a board that floats BOOT0 pin?
You've coded something with a dependency, perhaps speed, and clock, or reliant on something the debugger sets or configures, and you don't?
YBAYR.1
YBAYR.1Author
YBAYR.1
YBAYR.1Author
I am using nucleo board (302re) my codes are like this
S.Ma
Principal
February 25, 2023
Issues sometime come from the floating pins for the STLink VCP RX/TX, or -if used- the MCO clock gen of STLink to target chip under debug.
YBAYR.1
YBAYR.1Author
Thank you very much for your comments.How to arrange for a commercial product. how to get debug? @S.Ma​ @Community member​
YBAYR.1
YBAYR.1Author
Yes. It could be because of that point. I'm trying to fix. Do you have any suggestions on how to debug the project to make it a product?
