2023-04-25 01:17 AM
I'm a beginner in working with Embedded Systems. I'm confused over OpenSTM32 System Workbench and Cube IDE. Could you please clarify me on this.
2023-04-25 02:43 AM
Welcome, @Karthikh_Amaran, to the community!
Well, that is a very generic question and has historical backgrounds, but they are not necessarily important for newcomers.
I'd recommend starting to read in the Developer Zone and maybe with a Jump Start.
Hope that helps?
/Peter
2023-04-25 02:43 AM
Hope that helps?
/Peter
2023-04-25 10:30 AM
If the problem is solved, please mark this thread as answered by selecting Select as best, as also explained here. This will help other users find that answer faster.
Good luck!
/Peter
