Wave generation of particular frequency.
‎2019-04-09 12:22 AM
By using timer I want to generate a wave of 27Mhz frequency. Present time I can generate only 13.48khz frequency wave. My timer settings are below please tell me how can I generate it.
static void MX_TIM2_Init(void)
TIM_ClockConfigTypeDef sClockSourceConfig;
TIM_MasterConfigTypeDef sMasterConfig;
TIM_OC_InitTypeDef sConfigOC;
htim2.Instance = TIM2;
htim2.Init.Prescaler =27;
htim2.Init.CounterMode = TIM_COUNTERMODE_UP;
htim2.Init.Period = 1000;
htim2.Init.ClockDivision = TIM_CLOCKDIVISION_DIV4;
htim2.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_ENABLE;
if (HAL_TIM_Base_Init(&htim2) != HAL_OK)
_Error_Handler(__FILE__, __LINE__);
sClockSourceConfig.ClockSource = TIM_CLOCKSOURCE_INTERNAL;
if (HAL_TIM_ConfigClockSource(&htim2, &sClockSourceConfig) != HAL_OK)
if (HAL_TIM_OC_Init(&htim2) != HAL_OK)
if (HAL_TIMEx_MasterConfigSynchronization(&htim2, &sMasterConfig) != HAL_OK)
sConfigOC.OCMode = TIM_OCMODE_TOGGLE;
sConfigOC.Pulse = 250;
sConfigOC.OCPolarity = TIM_OCPOLARITY_HIGH;
sConfigOC.OCFastMode = TIM_OCFAST_DISABLE;
if (HAL_TIM_OC_ConfigChannel(&htim2, &sConfigOC, TIM_CHANNEL_4) != HAL_OK)
HAL_TIM_MspPostInit(&htim2);
STM32CubeMX
TIM
‎2019-04-13 1:28 AM
Please suggest how can in generate a wave of 27Mhz frequency. Timer settings are mentioned in above massage.
‎2019-04-13 1:47 AM
Can you please detail which STM32 device, and APB Clock frequency you have set ?
Change htim2.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
Not TIM_CLOCKDIVISION_DIV4;
27MHz / 4 = 6.75 which is the half of 13.5MHz you measure.
BR
rrom
‎2019-04-13 2:17 AM
Ok. I will cange it.
I am using STM32f207ZGT6.
‎2019-04-13 2:23 AM
Sorry it is "change" not cange.
‎2019-04-13 2:50 AM
if you core runs at 108 MHz and say this goes direct to feed timer clock, your timer can count only up to 4 as period.
Then set the toggle point to 2 and you get 50% duty cycle at 27MHz.
0123012301230123
__--__--__--__--__
Or more fun, if you use a SPI as master with DMA cyclical to a dummy buffer, its maximum clock SCK will run at SYSCLK/2 = 54 MHz (if fast SPI, STM32 family dependent)
‎2019-04-13 2:54 AM
Also look at MCU output pin, which can output internal clock with simple prescale factor. Simple cheap, keeps more complex peripherals available.
==> Reference Manual
‎2019-04-13 3:56 AM
System clock settings :-
void SystemClock_Config(void)
RCC_OscInitTypeDef RCC_OscInitStruct;
RCC_ClkInitTypeDef RCC_ClkInitStruct;
/**Initializes the CPU, AHB and APB busses clocks
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
RCC_OscInitStruct.HSEState = RCC_HSE_ON;
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
RCC_OscInitStruct.PLL.PLLM = 4;
RCC_OscInitStruct.PLL.PLLN = 216;
RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV4;
RCC_OscInitStruct.PLL.PLLQ = 4;
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV8;
RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_3) != HAL_OK)
/**Configure the Systick interrupt time
HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
/* SysTick_IRQn interrupt configuration */
HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
‎2019-04-13 3:57 AM
cubmex clock config window.
