2019-02-05 1:12 PM
I am having a strange problem with FreeRTOS in CubeMX, I cannot get multiple tasks to work concurrently. I use the following procedure -
Pre: Check STM32Cube_FW is fresh (v1.9.0 used)
For the example above myTask02 fires but the defaultTask does not, what am I missing to get both working? This has always worked for me before, what is wrong now?
2019-02-05 1:43 PM
Solved it, sharing response if useful for others. In the example listed above all task timing is aligned, e.g. StartDefaultTask() & StartTask02() look like this -
void taskExample(void const * argument) {
for(;;) {
osDelay(1);
So they clobber each other. Solution? Introduce timing offsets, e.g. change the osDelay() value for each task. Done!
2019-02-05 1:43 PM
for(;;) {
osDelay(1);
