2024-11-25 09:44 AM - last edited on 2024-11-25 09:51 AM by Andrew Neil
When I change a pin configuration, the user-label I'd previously given the pin is removed and it reverts to the default.
That seems to me to be a wrong behaviour ... I think it should stick be default, or should have an option to lock it.
This was raised by Arnold Bischoff back in 2016 and seemed acknowledged, but I think nothing has since happened on it.
2024-11-26 02:47 AM
Hello @gordon239955_st ,
A change request is submitted to the concerned team under this internal Ticket:197023.
Mahmoud
2024-11-26 01:06 AM
You request is under investigation, and I will get back to you ASAP.
Thanks.
Mahmoud
2024-11-26 02:47 AM
Mahmoud
2024-11-26 07:07 AM
Excellent. Thank you.
