2016-12-06 09:20 AM
The define USBD_CDC_INTERVAL in usbd_conf.h generated with CubeMX is not used anywhere in the project. It was used in the old USB Library in the usbd_cdc_core.c SOF-Function, which no longer exists.
#f4 #usb #cubemx #cdc #vcpSolved! Go to Solution.
2016-12-06 10:29 AM
Hi
nathancdc
,Thanks for the feedback. I submit it to our CubeMx team for check.
-Walid FTITI-
2016-12-06 10:29 AM
Hi
nathancdc
-Walid FTITI-
2017-07-05 08:15 AM
Hello All,
I confirm that this define will be removed from CubeMx4.22.
It will be available in W28.
Kind regards
Sirma
