stm32l4xx_hal_conf.h declaration of assert_failed() broken in STM32Cube_FW_L4_V1.15.0 ?
‎2020-02-18 1:30 PM
the file stm32l4xx_hal_conf.h in firmware repository STM32Cube_FW_L4_V1.15.0
contains a datatype mismatch in parameter 1 between the invokation and declaration of assert_failed() :
#define assert_param(expr) ((expr) ? (void)0U : assert_failed((uint8_t *)__FILE__, __LINE__))
void assert_failed(char *file, uint32_t line);
The compiler correctly warns of this mismatch when compiling stm32l4xx_hal_dma.c, stm32l4xx_hal_flash.c, stm32l4xx_hal_exti.c, stm32l4xx_hal_flash_ex.c, etc.
stm32l4xx_hal_conf.h:437:65: warning: pointer targets in passing argument 1 of 'assert_failed' differ in signedness [-Wpointer-sign]
Earlier versions of stm32l4xx_hal_conf.h did not contain this mismatch:
void assert_failed(uint8_t* file, uint32_t line);
Why was this change introduced, and will it be corrected?
‎2020-02-26 5:59 AM
Hi @Dean Neumann​ ,
Could you please precise which compiler are you using?
Thanks,
Amel
‎2020-02-29 6:12 PM
Regards,
Dean
‎2020-05-26 8:59 AM
Hello @Dean Neumann​ ,
I checked that there is no more such issue With STM32CubeMX 5.6. Please check again on your side.
-Amel
‎2020-05-26 9:26 AM
Please ignore about my previous comment, I checked for STM32F0 where there is no such issue. For STM32L4, problem is still there.
‎2020-05-27 2:28 AM
Thanks for the feedback,
Issue confirmed, it will be fixed as soon as possible.
Best regards,
Nesrine
