STM32G474 DAC with DMA doesnt work
‎2022-01-18 6:51 AM
I have trying DAC with DMA from STM32G474 eval board. I can see the values being updated to the DOR register and the DAC EN is set to 1. However, the output of the DAC is stuck at 0.
I have attached the cubeide settings.
- Labels:
DAC
DMA
STM32CubeMX
STM32G4 Series
‎2022-01-18 7:09 AM
Initialize it as GPIO output and toggle. Does it move?
There are some solder bridges and switches that can affect how PA4 is routed. See user manual.
‎2022-01-18 7:09 AM
‎2022-01-19 12:54 AM
I didnt realise that the A4 and PA4 are not the same. I checked the schematic after your comment and the problem is fixed. PA4 is connected to A2 pin on the board.
