Stm32f407ve ADC+DMA used 1KHz sin is not read evenly when reading the reason
Jkong.1
Stm32f407ve used ADC+DMA used 1KHz sin is not read evenly when reading the reason
0693W000008GNiKQAW.jpgExternal 8MHz crystal and UART asynchronous use
0693W000008GNlxQAG.jpg0693W000008GNlJQAW.jpg0693W000008GNl4QAG.jpg0693W000008GNkzQAG.jpg
You don't look to be pacing with a TIM, assume that you are saturating the USART.​
I did not use the TIM. How to fix if USART is saturated? The code using USART was uploaded as a photo attachment.
