STM32CubeMX v4.27.0 Do not generate main() doesn't set in GUI, when re-opening project file
‎2018-09-11 11:19 PM
I opened a project, upgraded to new CubeMX. Checked this option, regenerated the project. After re-opening the CubeMX file, this option is still set, because generation work correctly (no main() generated), but GUI isn't show it as set. The "set" sign (idk what is proper name for this :)) is missing.
After opening settings tab, clicking on OK will result in re-generating main().
‎2018-09-12 4:28 AM
Hi @kurta999​ ,
This is reported internally for further check.
Sorry for any inconvenience this may have caused.
Khouloud.
‎2018-10-09 8:46 AM
Hello @kurta999​ ,
Sorry for the late response.
I'm not able to reproduce the issue with STM32CubeMX v4.27.0 (migrated from 4.26.1).
Could you please send me the ioc.
Houda
‎2019-01-09 6:31 AM
‎2019-02-26 12:03 PM
Is this bug planned to be fixed in near futire? Tested with 5.1.0, sadly still nothing changed.
‎2019-02-26 12:04 PM
‎2019-02-27 7:16 AM
​Hello @kurta999​
Sorry for the delay in answering,
I have reported this issue and it will be fixed in the next CubeMX release.
Sorry again and thank you for the feedback.
Best Regards,
Khouloud.
‎2019-02-27 10:52 AM
Thank you!
‎2019-04-28 4:08 AM
Is this bug planned to be fixed in near future? Tested with CubeMX 5.2.0, same behaviour as before. Nothing changed.
