2017-06-20 08:49 AM
Since my last update of WIN10, Java and STM32CubeMX (I did all after Windows update) my STM32 Cube MX crashed on lot of actions : can not load a project, can not save project etc... Any suggestion ?
My PC runs WIN10 64bit
#java8 #cubemx-4.212017-06-21 02:13 AM
Hi
TRAN.Vu
,Thank you for your reported issue.
This is known issue in CubeMX with Windows 10/Java 8 and it is under investigation by ourteam.
Imen2017-06-24 07:35 AM
if you first create a 'Project name' in 'Generate Project report files' or 'Generate source code..' the saving with 'CTRL+S' works without crash.
'Load Project' CTRL+L doesn't work. I used 'Recent projects'
It's only a workaround. ST please correct the bug. (;-)
Ralph
PS: WIN10 Pro - 64Bit, Java 1.8.0_131 x86_64, STM32CubeMX 4.21.0
2017-06-25 09:01 AM
Hi Ralph, Thank For your advice, I cam at least continue working with this tip.
Reagrds
2017-07-15 06:33 AM
Try this
Remove Windows 10 'GodMode shortcut'
Thanks to:
https://stackoverflow.com/questions/43836174/java-applications-crash-when-browse-control-used
After erase, it work's
RDE
2017-07-18 09:27 AM
Hi Ralph, I confirm efficiency of your tip... Many thanks.
Cheer
