STM32CubeMX not setting the mcu when generating code.
‎2021-02-18 5:18 PM
I have a new pc with STM32CubeMX 6.1.1 and SW4STM32/OpenSTM32 IDE version 2.9.1.
I created a simple project setting mcu to STM32L475GTx, activated a few pins and generated code. The project generated has no mcu selected. What is set up incorrectly in my cube project?
STM32CubeMX
STM32L4 series
‎2021-02-19 1:38 AM
Hello @Community member​ ,
The issue isn't reproduced from my side, generating your attached project with SW4STM32 IDE the MCU is correctly set :
What I recommend here is to use the latest version of STM32CubeIDE since it is based on the Eclipse®/CDT framework and GCC toolchain for the development, and GDB for the debugging. It is also integrating STM32 configuration and project creation functionalities from STM32CubeMX.
Hope this helps you.
Khouloud.
‎2021-02-19 9:15 AM
Khouloud,
Thanks for trying this out.
If I were starting from scratch, STM32CubeIDE would be the way to go. Unfortunately I have many projects with many ioc files already in process. I was concerned about the time in conversion to the new tool and new HAL structure. I was hoping that STMCubeMX is still a supported product.
Thanks,
-Phil
‎2021-02-19 9:41 AM
Hi @Community member​ ,
You can easily import your project from SW4STM32 to STM32CubeIDE, following the available Migration guide from System Workbench to STM32CubeIDE.
Otherwise, STM32CubeMX is certainly still a supported product.
But I don't think that your issue is related to CubeMX since using your attached .ioc I do not reproduce the issue from my side.
Khouloud.
‎2021-02-19 11:10 AM
Hi Khouloud,
One last question, can SW4STM32 and STM32CubeIDE live side by side or must SW4STM32 be removed before an install of STM32CubeIDE? I wouldn't expect them to run simultaneously but can they be resident together on the same pc.
Thanks,
-Phil
‎2021-02-22 1:03 AM
It's not mandatory to remove SW4STM32 from your machine before installing STM32CubeIDE. You can have both of them on the same pc without any problem.
Khouloud.
‎2021-02-23 10:32 AM
Hi Khouloud,
Thanks for the response. I will be trying the STM32CubeIDE soon as my schedule allows.
-Phil
