STM32CubeMX not running
Posted on January 14, 2016 at 09:55
My installation of STM32CubeMX is not working.
I tried to reinstall the application but the Windows Control Panel -> Programs and Features Uninstall function does not work.
I deleted the installation directory manually and installed the application without success.
When I try to run the application STM32CubeMX.exe I see a window popping up for a short time:
Can anyboldy help me?
Thanks,
Martin
#stm32cubemx #bug #stm32cube
6 REPLIES 6
mikael23
Posted on January 14, 2016 at 10:23
I have the same problem !
Posted on January 15, 2016 at 12:02
Hi all,
Which version of java are you using?
-Shahrzad-
Posted on January 15, 2016 at 13:26
I have installed Java Version 8 Update 66.
mikael23
Posted on January 15, 2016 at 13:41
The same. (on a 32bits)
But on other PC (64bits Java 8 update 66) STM32CubeMX is running
mikael23
Posted on January 20, 2016 at 08:17
Anybody have solution?
Posted on January 28, 2016 at 11:08
Hi jacob.mikael,
STM32CubeMX is running with java 8 (update 66) on windows 7 and windows 8 (32 bits ans 64 bits).
Which windows version are you using? Could you send us the STM32CubeMx.log file under C:\Users\yoursession\.stm32cubemx?
-Shahrzad-
