2024-09-27 11:28 PM - last edited on 2024-09-30 1:58 AM by Andrew Neil
Hi!
STM32CubeMX generated an incorrect linker file, and I can't build the project with cmake.
Example project attached to the post.
cmake version - 3.28.1
STM32CubeMX version 6.12.1
2024-12-02 12:25 AM
Hello @ATkac.3
This behavior has been solved on the last version of the STM32CubeMX V6.13.0. Thank you so much for reporting.
Best Regards.
STTwo-32
2024-09-28 7:32 AM - edited 2024-09-28 7:32 AM
What is incorrect about it? Why can't you build the project? Show more information, error messages, screenshots, etc.
2024-09-28 12:38 PM - edited 2024-09-28 12:40 PM
Yes this is a known issue, already in handling.
2024-09-30 1:47 AM - edited 2024-12-05 1:26 AM
Hello @ATkac.3 ,
First let me thank you for posting.
I suggest that you take a look at this Post.
This issue was sent to the concerned team (under internal ticket number 191745).
Best Regards.
Mahmoud
2024-12-02 12:25 AM
Hello @ATkac.3
Best Regards.
STTwo-32
