Exception in thread "Browser Thread: af1bad7e-9d54-4fea-bf81-810f805fadf1" Exception in thread "Render Thread: 1e9167c2-a7d4-47ff-a51f-8766ace40d51" java.lang.IllegalStateException: Failed to receive the response.
at com.teamdev.jxbrowser.internal.rpc.transport.RpcThreadCallExecutor.execute(RpcThreadCallExecutor.java:43)
at com.teamdev.jxbrowser.internal.rpc.ServiceConnectionImpl.invoke(ServiceConnectionImpl.java:213)
at com.teamdev.jxbrowser.frame.internal.FrameImpl.document(FrameImpl.java:449)
at com.st.microxplorer.plugins.userauth.WebApp.findElementsByTagName(WebApp.java:723)
at com.st.microxplorer.plugins.userauth.WebApp.removeUnecessaryTags(WebApp.java:806)
at com.st.microxplorer.plugins.userauth.WebApp.lambda$new$9(WebApp.java:193)
at com.teamdev.jxbrowser.event.internal.NewObservableHelper.notifyObservers(NewObservableHelper.java:57)
at com.teamdev.jxbrowser.internal.rpc.stream.EventStream.dispatch(EventStream.java:74)
at com.teamdev.jxbrowser.internal.rpc.stream.EventStream.process(EventStream.java:126)
at com.teamdev.jxbrowser.internal.rpc.stream.Stream$StreamObserver.lambda$onNext$0(Stream.java:167)
at com.teamdev.jxbrowser.internal.RpcThreadImpl$TaskRunner.processTasks(RpcThreadImpl.java:172)
at java.base/java.lang.Thread.run(Thread.java:833)
Caused by: java.lang.IllegalStateException: The connection has been closed.
at com.teamdev.jxbrowser.internal.rpc.transport.RpcThreadCallExecutor.lambda$execute$0(RpcThreadCallExecutor.java:35)
at com.teamdev.jxbrowser.deps.com.google.protobuf.RpcUtil$1.run(RpcUtil.java:79)
at com.teamdev.jxbrowser.deps.com.google.protobuf.RpcUtil$1.run(RpcUtil.java:70)
at com.teamdev.jxbrowser.internal.rpc.ServiceChannel$1.onError(ServiceChannel.java:76)
at com.teamdev.jxbrowser.internal.rpc.transport.SharedMemoryTransport.lambda$close$1(SharedMemoryTransport.java:132)
at java.base/java.util.concurrent.ConcurrentHashMap.forEach(ConcurrentHashMap.java:1603)
at com.teamdev.jxbrowser.internal.rpc.transport.SharedMemoryTransport.close(SharedMemoryTransport.java:130)
at com.teamdev.jxbrowser.internal.rpc.transport.RpcConnection.close(RpcConnection.java:51)
at com.teamdev.jxbrowser.internal.rpc.transport.ConnectionChecker.run(ConnectionChecker.java:41)
... 1 more
java.lang.NullPointerException: Cannot invoke "com.teamdev.jxbrowser.deps.com.google.protobuf.StringValue.getValue()" because the return value of "com.teamdev.jxbrowser.internal.rpc.UniversalServiceConnection.invoke(com.teamdev.jxbrowser.internal.rpc.ServiceMethod, com.teamdev.jxbrowser.deps.com.google.protobuf.Message)" is null
at com.teamdev.jxbrowser.browser.internal.BrowserImpl.url(BrowserImpl.java:448)
at com.st.microxplorer.plugins.userauth.WebApp.lambda$new$0(WebApp.java:169)
at com.teamdev.jxbrowser.frame.internal.FrameImpl.lambda$processCallback$2(FrameImpl.java:187)
at java.base/java.util.Optional.map(Optional.java:260)
at com.teamdev.jxbrowser.frame.internal.FrameImpl.processCallback(FrameImpl.java:187)
at com.teamdev.jxbrowser.internal.rpc.stream.CallbackStream.process(CallbackStream.java:181)
11:41:50.010 ERROR The response observer has thrown an exception.
at com.teamdev.jxbrowser.deps.com.google.common.base.Preconditions.checkState(Preconditions.java:494)
at com.teamdev.jxbrowser.internal.RpcThreadImpl.exitNestedLoop(RpcThreadImpl.java:137)
at com.teamdev.jxbrowser.internal.rpc.transport.RpcThreadCallExecutor.lambda$execute$0(RpcThreadCallExecutor.java:39)
11:41:50.030 ERROR Chromium process exit code: 137
11:41:50.031 ERROR Crash dump dir: /Users/dimmorpheus/Library/Application Support/JxBrowser/7.30.2/CrashReports
2023-07-27 11:41:50,032 [ERROR] WebApp:339 - JxBrowser engine crashed! Exit code: 137
![Screen Shot 2023-07-27 at 11.43.58 AM.png Screen Shot 2023-07-27 at 11.43.58 AM.png](https://community.st.com/t5/image/serverpage/image-id/51476i91D1B2F243820424/image-size/large/is-moderation-mode/true?v=v2&px=999)
