stm32cubemx fails to download packages
dimmorpheus
stm32cubemx fails to download packages due to inability to authorize at "myST->login".
According to the crash dump it has happend because of jxbrowser plugin-7.30.2 (chomium version 108.0.5359.215).
All extended attributes had been cleared (not trusted software etc), all neccessary execution bits are set, firewall is turned off.
Please see the log below.
Could anybody help me? Is there any other way to autorise the app?
Log:
Spoiler
Exception in thread "Browser Thread: af1bad7e-9d54-4fea-bf81-810f805fadf1" Exception in thread "Render Thread: 1e9167c2-a7d4-47ff-a51f-8766ace40d51" java.lang.IllegalStateException: Failed to receive the response.
at com.teamdev.jxbrowser.internal.rpc.transport.RpcThreadCallExecutor.execute(RpcThreadCallExecutor.java:43)
at com.teamdev.jxbrowser.internal.rpc.ServiceConnectionImpl.invoke(ServiceConnectionImpl.java:213)
at com.teamdev.jxbrowser.frame.internal.FrameImpl.document(FrameImpl.java:449)
at com.st.microxplorer.plugins.userauth.WebApp.findElementsByTagName(WebApp.java:723)
at com.st.microxplorer.plugins.userauth.WebApp.removeUnecessaryTags(WebApp.java:806)
at com.st.microxplorer.plugins.userauth.WebApp.lambda$new$9(WebApp.java:193)
at com.teamdev.jxbrowser.event.internal.NewObservableHelper.notifyObservers(NewObservableHelper.java:57)
at com.teamdev.jxbrowser.internal.rpc.stream.EventStream.dispatch(EventStream.java:74)
at com.teamdev.jxbrowser.internal.rpc.stream.EventStream.process(EventStream.java:126)
at com.teamdev.jxbrowser.internal.rpc.stream.Stream$StreamObserver.lambda$onNext$0(Stream.java:167)
at com.teamdev.jxbrowser.internal.RpcThreadImpl$TaskRunner.processTasks(RpcThreadImpl.java:172)
at java.base/java.lang.Thread.run(Thread.java:833)
Caused by: java.lang.IllegalStateException: The connection has been closed.
at com.teamdev.jxbrowser.internal.rpc.transport.RpcThreadCallExecutor.lambda$execute$0(RpcThreadCallExecutor.java:35)
at com.teamdev.jxbrowser.deps.com.google.protobuf.RpcUtil$1.run(RpcUtil.java:79)
at com.teamdev.jxbrowser.deps.com.google.protobuf.RpcUtil$1.run(RpcUtil.java:70)
at com.teamdev.jxbrowser.internal.rpc.ServiceChannel$1.onError(ServiceChannel.java:76)
at com.teamdev.jxbrowser.internal.rpc.transport.SharedMemoryTransport.lambda$close$1(SharedMemoryTransport.java:132)
at java.base/java.util.concurrent.ConcurrentHashMap.forEach(ConcurrentHashMap.java:1603)
at com.teamdev.jxbrowser.internal.rpc.transport.SharedMemoryTransport.close(SharedMemoryTransport.java:130)
at com.teamdev.jxbrowser.internal.rpc.transport.RpcConnection.close(RpcConnection.java:51)
at com.teamdev.jxbrowser.internal.rpc.transport.ConnectionChecker.run(ConnectionChecker.java:41)
... 1 more
java.lang.NullPointerException: Cannot invoke "com.teamdev.jxbrowser.deps.com.google.protobuf.StringValue.getValue()" because the return value of "com.teamdev.jxbrowser.internal.rpc.UniversalServiceConnection.invoke(com.teamdev.jxbrowser.internal.rpc.ServiceMethod, com.teamdev.jxbrowser.deps.com.google.protobuf.Message)" is null
at com.teamdev.jxbrowser.browser.internal.BrowserImpl.url(BrowserImpl.java:448)
at com.st.microxplorer.plugins.userauth.WebApp.lambda$new$0(WebApp.java:169)
at com.teamdev.jxbrowser.frame.internal.FrameImpl.lambda$processCallback$2(FrameImpl.java:187)
at java.base/java.util.Optional.map(Optional.java:260)
at com.teamdev.jxbrowser.frame.internal.FrameImpl.processCallback(FrameImpl.java:187)
at com.teamdev.jxbrowser.internal.rpc.stream.CallbackStream.process(CallbackStream.java:181)
11:41:50.010 ERROR The response observer has thrown an exception.
at com.teamdev.jxbrowser.deps.com.google.common.base.Preconditions.checkState(Preconditions.java:494)
at com.teamdev.jxbrowser.internal.RpcThreadImpl.exitNestedLoop(RpcThreadImpl.java:137)
at com.teamdev.jxbrowser.internal.rpc.transport.RpcThreadCallExecutor.lambda$execute$0(RpcThreadCallExecutor.java:39)
11:41:50.030 ERROR Chromium process exit code: 137
11:41:50.031 ERROR Crash dump dir: /Users/dimmorpheus/Library/Application Support/JxBrowser/7.30.2/CrashReports
2023-07-27 11:41:50,032 [ERROR] WebApp:339 - JxBrowser engine crashed! Exit code: 137
21 REPLIES 21
Ghofrane GSOURI
Hello @dimmorpheus
First let me thank you for posting.
Could you please try to follow those steps then provide the STM32CubeMX.log:
- Delete user/.Stm32CubeMx
- Run STM32CubeMx 6.9.0
-Click on MyST-->login
-Click on Help -->Updater settings -->Connection parameters --> then check your connection
I will be waiting for your feedback.
Thx
Ghofrane
-MyST-->login
Hello. Thank you for the answer.
I'd done all the things you're written.
The same thing.
Please see the content of the 'STM32CubeMX.log' below.
Also I've tried:
- use another Java VM instead of bundled with STM32CubeMX by changing symbolic link '
STM32CubeMX.app/Contents/Resources/jre' to more recent JVM (
20.0.2+9-78).
- use another Chromium build (/.stm32cubemx/.jxbrowser-7.30.2/Chromium).
Nothing helps.
Spoiler
2023-07-28 08:45:59,136 [INFO] MicroXplorer:98 - [MX] MX Start == 691438184574
2023-07-28 08:45:59,138 [INFO] MicroXplorer:653 - Detected Java Version = 17.0.6
2023-07-28 08:45:59,540 [INFO] ApplicationProperties:184 - Using Application install path: /Applications/STMicroelectronics/STM32CubeMX.app/Contents/Resources
2023-07-28 08:45:59,556 [INFO] DbMcusXml:78 - Set database path to: /Applications/STMicroelectronics/STM32CubeMX.app/Contents/Resources//db//mcu/
2023-07-28 08:45:59,557 [INFO] ApiDb:274 - Set plugin database path to: /Applications/STMicroelectronics/STM32CubeMX.app/Contents/Resources//db//plugins/boardmanager/
2023-07-28 08:45:59,557 [WARN] ApiDb:259 - Overriding images path with different value: => /Applications/STMicroelectronics/STM32CubeMX.app/Contents/Resources//db//plugins/mcufinder/images/
2023-07-28 08:45:59,561 [INFO] McuFinderGlobals:63 - Set McuFinder mode to 1 (CubeMX integrated)
2023-07-28 08:45:59,572 [INFO] ApiDb:250 - Set database path to: /Users/dimmorpheus/.stmcufinder/plugins/mcufinder//mcu/
2023-07-28 08:45:59,573 [INFO] DbMcusAds:125 - Set database path to: /Users/dimmorpheus/.stmcufinder/plugins/mcufinder//mcu/
2023-07-28 08:45:59,577 [INFO] CrossReferenceDbSqlite:203 - Set database path to: /Users/dimmorpheus/.stmcufinder/plugins/mcufinder//mcu/cs/
2023-07-28 08:45:59,702 [INFO] RulesReader:64 - Compatibility file has been processed (293 Rules)
2023-07-28 08:45:59,727 [INFO] STM32CubeMX:60 - Starting STM32CubeMX
2023-07-28 08:46:00,130 [INFO] MainPanel:262 - HeapMemory: 71303168
2023-07-28 08:46:00,242 [INFO] DbMcusXml:78 - Set database path to: /Applications/STMicroelectronics/STM32CubeMX.app/Contents/Resources//db//mcu/
2023-07-28 08:46:00,242 [INFO] ApiDb:274 - Set plugin database path to: /Applications/STMicroelectronics/STM32CubeMX.app/Contents/Resources//db//plugins/boardmanager/
2023-07-28 08:46:00,242 [INFO] ApiDb:261 - Set plugin images path to: /Applications/STMicroelectronics/STM32CubeMX.app/Contents/Resources//db//plugins/mcufinder/images/
2023-07-28 08:46:00,243 [WARN] DbFile:41 - Overriding database path with different value: /Users/dimmorpheus/.stmcufinder/plugins/mcufinder/ => /Users/dimmorpheus/.stmcufinder/plugins/mcufinder
2023-07-28 08:46:00,243 [INFO] ApiDb:250 - Set database path to: /Users/dimmorpheus/.stmcufinder/plugins/mcufinder//mcu/
2023-07-28 08:46:00,243 [INFO] DbMcusAds:125 - Set database path to: /Users/dimmorpheus/.stmcufinder/plugins/mcufinder//mcu/
2023-07-28 08:46:00,244 [WARN] DbFile:41 - Overriding database path with different value: /Users/dimmorpheus/.stmcufinder/plugins/mcufinder/ => /Users/dimmorpheus/.stmcufinder/plugins/mcufinder
2023-07-28 08:46:00,244 [INFO] CrossReferenceDbSqlite:203 - Set database path to: /Users/dimmorpheus/.stmcufinder/plugins/mcufinder//mcu/cs/
2023-07-28 08:46:00,258 [INFO] ApplicationProperties:184 - Using Application install path: /Applications/STMicroelectronics/STM32CubeMX.app/Contents/Resources
2023-07-28 08:46:00,260 [INFO] PluginManage:196 - Search for loadable plugins [exclusion list=, ]
2023-07-28 08:46:00,261 [INFO] PluginManage:310 - Check plugin analytics
2023-07-28 08:46:00,517 [INFO] AnalyticsPlugin:253 - Accepted Software Licenses: STM32CubeMX.6.9.0
2023-07-28 08:46:00,518 [INFO] AnalyticsPlugin:255 - Accepted CMSIS Pack Licenses:
2023-07-28 08:46:00,518 [INFO] AnalyticsPlugin:257 - Accepted Firmware Licenses:
2023-07-28 08:46:00,522 [INFO] PluginManage:359 - Loaded plugin analytics (category:tool,tabindex:-1)
2023-07-28 08:46:00,522 [INFO] PluginManage:310 - Check plugin cadmodel
2023-07-28 08:46:00,526 [INFO] CADModel:105 - Init CAD model plugin
2023-07-28 08:46:00,526 [INFO] PluginManage:359 - Loaded plugin cadmodel (category:power,tabindex:5)
2023-07-28 08:46:00,526 [INFO] PluginManage:310 - Check plugin clock
2023-07-28 08:46:00,533 [INFO] PluginManage:359 - Loaded plugin clock (category:base,tabindex:2)
2023-07-28 08:46:00,533 [INFO] PluginManage:310 - Check plugin ddr
2023-07-28 08:46:00,535 [INFO] PluginManage:359 - Loaded plugin ddr (category:tool,tabindex:6)
2023-07-28 08:46:00,536 [INFO] PluginManage:310 - Check plugin filemanager
2023-07-28 08:46:00,666 [INFO] PluginManage:359 - Loaded plugin filemanager (category:base,tabindex:10)
2023-07-28 08:46:00,666 [INFO] PluginManage:310 - Check plugin ipmanager
2023-07-28 08:46:00,687 [INFO] PluginManage:359 - Loaded plugin ipmanager (category:base,tabindex:5)
2023-07-28 08:46:00,687 [INFO] PluginManage:310 - Check plugin lpbam
2023-07-28 08:46:00,695 [INFO] PluginManage:359 - Loaded plugin lpbam (category:base,tabindex:0)
2023-07-28 08:46:00,695 [INFO] PluginManage:310 - Check plugin memorymap
2023-07-28 08:46:00,708 [INFO] PluginManage:359 - Loaded plugin memorymap (category:base,tabindex:4)
2023-07-28 08:46:00,709 [INFO] PluginManage:310 - Check plugin pinoutandconfiguration
2023-07-28 08:46:00,716 [INFO] PluginManage:359 - Loaded plugin pinoutandconfiguration (category:base,tabindex:1)
2023-07-28 08:46:00,717 [INFO] PluginManage:310 - Check plugin pinoutconfig
2023-07-28 08:46:00,804 [WARN] SupportedApi:132 - Cannot load RTOS API schema: s4s-elt-must-match.1: The content of 'definitions' must match (annotation?, (simpleType | complexType)?, (unique | key | keyref)*)). A problem was found starting at: attribute.
2023-07-28 08:46:00,967 [INFO] PluginManage:359 - Loaded plugin pinoutconfig (category:base,tabindex:0)
2023-07-28 08:46:00,968 [INFO] PluginManage:310 - Check plugin power
2023-07-28 08:46:00,976 [INFO] PluginManage:359 - Loaded plugin power (category:power,tabindex:4)
2023-07-28 08:46:00,976 [INFO] PluginManage:310 - Check plugin projectmanager
2023-07-28 08:46:01,048 [INFO] PluginManage:359 - Loaded plugin projectmanager (category:projectmanager,tabindex:3)
2023-07-28 08:46:01,048 [INFO] PluginManage:310 - Check plugin thirdparty
2023-07-28 08:46:01,158 [INFO] PluginManage:359 - Loaded plugin thirdparty (category:base,tabindex:-1)
2023-07-28 08:46:01,158 [INFO] PluginManage:310 - Check plugin tools
2023-07-28 08:46:01,158 [WARN] IntegrityCheckThread:84 - waiting for thirdparty lock release [integrity check]
2023-07-28 08:46:01,159 [INFO] IntegrityCheckThread:86 - entering critical section [integrity check]
2023-07-28 08:46:01,159 [INFO] ThirdPartyUpdaterWithRetryManager:70 - Updater plugin not ready yet. [1/15]
2023-07-28 08:46:01,160 [INFO] PluginManage:359 - Loaded plugin tools (category:base,tabindex:7)
2023-07-28 08:46:01,160 [INFO] PluginManage:310 - Check plugin tutovideos
2023-07-28 08:46:01,309 [INFO] PluginManage:359 - Loaded plugin tutovideos (category:base,tabindex:-1)
2023-07-28 08:46:01,309 [INFO] PluginManage:310 - Check plugin updater
2023-07-28 08:46:01,325 [INFO] PluginManage:359 - Loaded plugin updater (category:base,tabindex:12)
2023-07-28 08:46:01,325 [INFO] PluginManage:310 - Check plugin userauth
2023-07-28 08:46:01,331 [INFO] UserAuth:113 - Init User Auth plugin
2023-07-28 08:46:01,331 [INFO] PluginManage:359 - Loaded plugin userauth (category:base,tabindex:14)
2023-07-28 08:46:01,332 [INFO] PluginManage:283 - PluginManage : Loaded plugins [17]
2023-07-28 08:46:01,493 [INFO] PinOutPanel:1499 - setPackage(No Configuration,No Configuration)
2023-07-28 08:46:01,575 [INFO] CADModel:165 - CPN selected for project level
2023-07-28 08:46:01,576 [INFO] CADModel:114 - Register for checkConnection events
2023-07-28 08:46:01,584 [INFO] IPUIPlugin:80 - create IPUIPlugin
2023-07-28 08:46:01,584 [INFO] PluginManager:220 - loadIPPluginJar : add mdma
2023-07-28 08:46:01,589 [INFO] IPUIPlugin:80 - create IPUIPlugin
2023-07-28 08:46:01,589 [INFO] PluginManager:220 - loadIPPluginJar : add freertos
2023-07-28 08:46:01,592 [INFO] IPUIPlugin:80 - create IPUIPlugin
2023-07-28 08:46:01,593 [INFO] PluginManager:220 - loadIPPluginJar : add gic
2023-07-28 08:46:01,599 [INFO] IPUIPlugin:80 - create IPUIPlugin
2023-07-28 08:46:01,599 [INFO] PluginManager:220 - loadIPPluginJar : add adc
2023-07-28 08:46:01,600 [INFO] IPUIPlugin:80 - create IPUIPlugin
2023-07-28 08:46:01,601 [INFO] PluginManager:220 - loadIPPluginJar : add gtzc
2023-07-28 08:46:01,602 [INFO] IPUIPlugin:80 - create IPUIPlugin
2023-07-28 08:46:01,602 [INFO] PluginManager:220 - loadIPPluginJar : add quadspi
2023-07-28 08:46:01,603 [INFO] IPUIPlugin:80 - create IPUIPlugin
2023-07-28 08:46:01,603 [INFO] PluginManager:220 - loadIPPluginJar : add aes
2023-07-28 08:46:01,605 [INFO] IPUIPlugin:80 - create IPUIPlugin
2023-07-28 08:46:01,605 [INFO] PluginManager:220 - loadIPPluginJar : add pdm2pcm
2023-07-28 08:46:01,606 [INFO] IPUIPlugin:80 - create IPUIPlugin
2023-07-28 08:46:01,607 [INFO] PluginManager:220 - loadIPPluginJar : add hash
2023-07-28 08:46:01,608 [INFO] IPUIPlugin:80 - create IPUIPlugin
2023-07-28 08:46:01,608 [INFO] PluginManager:220 - loadIPPluginJar : add tim
2023-07-28 08:46:01,609 [INFO] IPUIPlugin:80 - create IPUIPlugin
2023-07-28 08:46:01,609 [INFO] PluginManager:220 - loadIPPluginJar : add tsc
2023-07-28 08:46:01,610 [INFO] IPUIPlugin:80 - create IPUIPlugin
2023-07-28 08:46:01,610 [INFO] PluginManager:220 - loadIPPluginJar : add ts
2023-07-28 08:46:01,612 [INFO] IPUIPlugin:80 - create IPUIPlugin
2023-07-28 08:46:01,612 [INFO] PluginManager:220 - loadIPPluginJar : add can
2023-07-28 08:46:01,614 [INFO] IPUIPlugin:80 - create IPUIPlugin
2023-07-28 08:46:01,614 [INFO] PluginManager:220 - loadIPPluginJar : add dma3
2023-07-28 08:46:01,615 [INFO] IPUIPlugin:80 - create IPUIPlugin
2023-07-28 08:46:01,615 [INFO] PluginManager:220 - loadIPPluginJar : add dfsdm
2023-07-28 08:46:01,616 [INFO] IPUIPlugin:80 - create IPUIPlugin
2023-07-28 08:46:01,617 [INFO] PluginManager:220 - loadIPPluginJar : add spi
2023-07-28 08:46:01,618 [INFO] IPUIPlugin:80 - create IPUIPlugin
2023-07-28 08:46:01,618 [INFO] PluginManager:220 - loadIPPluginJar : add gfxmmu
2023-07-28 08:46:01,619 [INFO] IPUIPlugin:80 - create IPUIPlugin
2023-07-28 08:46:01,619 [INFO] PluginManager:220 - loadIPPluginJar : add genericplugin
2023-07-28 08:46:01,620 [INFO] IPUIPlugin:80 - create IPUIPlugin
2023-07-28 08:46:01,620 [INFO] PluginManager:220 - loadIPPluginJar : add cryp
2023-07-28 08:46:01,623 [INFO] IPUIPlugin:80 - create IPUIPlugin
2023-07-28 08:46:01,623 [INFO] PluginManager:220 - loadIPPluginJar : add gpio
2023-07-28 08:46:01,624 [INFO] IPUIPlugin:80 - create IPUIPlugin
2023-07-28 08:46:01,624 [INFO] PluginManager:220 - loadIPPluginJar : add comp
2023-07-28 08:46:01,625 [INFO] IPUIPlugin:80 - create IPUIPlugin
2023-07-28 08:46:01,626 [INFO] PluginManager:220 - loadIPPluginJar : add tracer_emb
2023-07-28 08:46:01,627 [INFO] IPUIPlugin:80 - create IPUIPlugin
2023-07-28 08:46:01,627 [INFO] PluginManager:220 - loadIPPluginJar : add openamp
2023-07-28 08:46:01,630 [INFO] IPUIPlugin:80 - create IPUIPlugin
2023-07-28 08:46:01,631 [INFO] PluginManager:220 - loadIPPluginJar : add stm32_wpan
2023-07-28 08:46:01,635 [INFO] IPUIPlugin:80 - create IPUIPlugin
2023-07-28 08:46:01,637 [INFO] PluginManager:220 - loadIPPluginJar : add plateformsettings
2023-07-28 08:46:01,640 [INFO] IPUIPlugin:80 - create IPUIPlugin
2023-07-28 08:46:01,640 [INFO] PluginManager:220 - loadIPPluginJar : add ipddr
2023-07-28 08:46:01,642 [INFO] IPUIPlugin:80 - create IPUIPlugin
2023-07-28 08:46:01,642 [INFO] PluginManager:220 - loadIPPluginJar : add usart
2023-07-28 08:46:01,643 [INFO] IPUIPlugin:80 - create IPUIPlugin
2023-07-28 08:46:01,643 [INFO] PluginManager:220 - loadIPPluginJar : add ltdc
2023-07-28 08:46:01,645 [INFO] IPUIPlugin:80 - create IPUIPlugin
2023-07-28 08:46:01,645 [INFO] PluginManager:220 - loadIPPluginJar : add nvic
2023-07-28 08:46:01,646 [INFO] IPUIPlugin:80 - create IPUIPlugin
2023-07-28 08:46:01,647 [INFO] PluginManager:220 - loadIPPluginJar : add fatfs
2023-07-28 08:46:01,651 [INFO] IPUIPlugin:80 - create IPUIPlugin
2023-07-28 08:46:01,651 [INFO] PluginManager:220 - loadIPPluginJar : add linkedlist
2023-07-28 08:46:01,655 [INFO] IPUIPlugin:80 - create IPUIPlugin
2023-07-28 08:46:01,655 [INFO] PluginManager:220 - loadIPPluginJar : add dma
2023-07-28 08:46:01,657 [INFO] IPUIPlugin:80 - create IPUIPlugin
2023-07-28 08:46:01,657 [INFO] PluginManager:220 - loadIPPluginJar : add fmc
2023-07-28 08:46:01,659 [INFO] IPUIPlugin:80 - create IPUIPlugin
2023-07-28 08:46:01,659 [INFO] PluginManager:220 - loadIPPluginJar : add i2s
2023-07-28 08:46:01,660 [INFO] IPUIPlugin:80 - create IPUIPlugin
2023-07-28 08:46:01,660 [INFO] PluginManager:220 - loadIPPluginJar : add ucpd
2023-07-28 08:46:01,661 [INFO] IPUIPlugin:80 - create IPUIPlugin
2023-07-28 08:46:01,662 [INFO] PluginManager:220 - loadIPPluginJar : add lorawan
2023-07-28 08:46:01,663 [INFO] IPUIPlugin:80 - create IPUIPlugin
2023-07-28 08:46:01,663 [INFO] PluginManager:220 - loadIPPluginJar : add opamp
2023-07-28 08:46:01,665 [INFO] IPUIPlugin:80 - create IPUIPlugin
2023-07-28 08:46:01,666 [INFO] PluginManager:220 - loadIPPluginJar : add i3c
2023-07-28 08:46:01,668 [INFO] IPUIPlugin:80 - create IPUIPlugin
2023-07-28 08:46:01,668 [INFO] PluginManager:220 - loadIPPluginJar : add touchsensing
2023-07-28 08:46:01,670 [INFO] IPUIPlugin:80 - create IPUIPlugin
2023-07-28 08:46:01,670 [INFO] PluginManager:220 - loadIPPluginJar : add i2c
2023-07-28 08:46:01,672 [INFO] IPUIPlugin:80 - create IPUIPlugin
2023-07-28 08:46:01,672 [INFO] PluginManager:220 - loadIPPluginJar : add resmgrutility
2023-07-28 08:46:01,674 [INFO] IPUIPlugin:80 - create IPUIPlugin
2023-07-28 08:46:01,674 [INFO] PluginManager:220 - loadIPPluginJar : add sai
2023-07-28 08:46:01,676 [INFO] IPUIPlugin:80 - create IPUIPlugin
2023-07-28 08:46:01,677 [INFO] PluginManager:220 - loadIPPluginJar : add usbx
2023-07-28 08:46:01,696 [INFO] Updater:1056 - Updater Version found : 6.9.0
2023-07-28 08:46:01,708 [INFO] ApplicationProperties:184 - Using Application install path: /Applications/STMicroelectronics/STM32CubeMX.app/Contents/Resources
2023-07-28 08:46:01,779 [INFO] MainUpdater:521 - Copy updater definitions from MX database
2023-07-28 08:46:01,813 [INFO] MainUpdater:554 - Copy flag file definitions from MX database
2023-07-28 08:46:01,814 [INFO] MainUpdater:570 - Copy thirdparty index definitions from MX database
2023-07-28 08:46:01,815 [INFO] MainUpdater:589 - Copy default thirdparty db definitions from MX database
2023-07-28 08:46:02,246 [INFO] MainUpdater:2868 - connection check result : 10
2023-07-28 08:46:02,246 [INFO] MainUpdater:3562 - Updater definition file requires update
2023-07-28 08:46:02,251 [INFO] MainUpdater:285 - Updater Check For Update Now.
2023-07-28 08:46:02,251 [INFO] MicroXplorer:498 - Change Database Version : DB.6.0.90
2023-07-28 08:46:02,283 [INFO] ServerAccessManage:473 - Download File updaters.zip
2023-07-28 08:46:02,341 [INFO] CADModel:165 - CPN selected for project level
2023-07-28 08:46:02,341 [INFO] CADModel:114 - Register for checkConnection events
2023-07-28 08:46:02,350 [INFO] FileExtend:240 - Unzip File : updaters.zip
2023-07-28 08:46:02,350 [INFO] FileExtend:255 - Standard Zip Deflate
2023-07-28 08:46:02,512 [INFO] CADModel:165 - CPN selected for project level
2023-07-28 08:46:02,512 [INFO] CADModel:114 - Register for checkConnection events
2023-07-28 08:46:02,556 [INFO] ServerAccessManage:473 - Download File PacksControlFlags.xml
2023-07-28 08:46:02,569 [INFO] HomeAdPanel:103 - Auto-refresh data requested => check proxy status ongoing
2023-07-28 08:46:02,572 [ERROR] WebUtils:647 - Updater is busy
2023-07-28 08:46:02,572 [ERROR] HomeAdPanel:119 - Failed to refresh advertisement data
2023-07-28 08:46:02,621 [INFO] DbMcusAds:53 - JSON generation date=Tue Mar 07 11:50:55 MSK 2023 (1678179055114)
2023-07-28 08:46:02,621 [ERROR] WebUtils:388 - Updater is busy
2023-07-28 08:46:02,628 [INFO] ServerAccessManage:473 - Download File cubemx.pidx
2023-07-28 08:46:02,680 [WARN] DetailPanel:346 - Failed to get advertising image, set to default
2023-07-28 08:46:02,728 [INFO] ServerAccessManage:473 - Download File STMicroelectronics.FP-ATR-ASTRA1.pdsc
2023-07-28 08:46:02,780 [ERROR] WebUtils:388 - Updater is busy
2023-07-28 08:46:02,812 [INFO] ServerAccessManage:473 - Download File STMicroelectronics.FP-ATR-SIGFOX1.pdsc
2023-07-28 08:46:02,854 [INFO] ServerAccessManage:473 - Download File STMicroelectronics.FP-SNS-FLIGHT1.pdsc
2023-07-28 08:46:02,930 [ERROR] WebUtils:388 - Updater is busy
2023-07-28 08:46:02,931 [WARN] DetailPanel:346 - Failed to get advertising image, set to default
2023-07-28 08:46:02,937 [INFO] ServerAccessManage:473 - Download File STMicroelectronics.FP-SNS-MOTENV1.pdsc
2023-07-28 08:46:03,010 [INFO] MainFrame:183 - [MX] HOME_PANEL == 695318495396
2023-07-28 08:46:03,017 [INFO] ServerAccessManage:473 - Download File STMicroelectronics.X-CUBE-AI.pdsc
2023-07-28 08:46:03,027 [INFO] UserAuth:179 - activating auth plugin
2023-07-28 08:46:03,039 [INFO] UserAuth:393 - Internet connection configuration mode: 1
2023-07-28 08:46:03,158 [INFO] JxBrowserEngine:151 - Initiate JxBrowser Engine with user profile folder
2023-07-28 08:46:03,286 [INFO] ServerAccessManage:473 - Download File STMicroelectronics.X-CUBE-ALS.pdsc
2023-07-28 08:46:03,353 [INFO] ServerAccessManage:473 - Download File STMicroelectronics.X-CUBE-BLE1.pdsc
2023-07-28 08:46:03,709 [ERROR] ServerAccessManage:1089 - Problem, file not found on Server
2023-07-28 08:46:03,726 [INFO] ServerAccessManage:473 - Download File STMicroelectronics.X-CUBE-BLE2.pdsc
2023-07-28 08:46:03,896 [INFO] ServerAccessManage:473 - Download File STMicroelectronics.X-CUBE-BLEMGR.pdsc
dimmorpheus
I'cant insert whole log file in one message.
So. There is the rest of the log file.
Spoiler
2023-07-28 08:46:04,017 [INFO] ServerAccessManage:473 - Download File STMicroelectronics.X-CUBE-DISPLAY.pdsc
2023-07-28 08:46:04,158 [INFO] ServerAccessManage:473 - Download File STMicroelectronics.X-CUBE-EEPRMA1.pdsc
2023-07-28 08:46:04,162 [WARN] MainUpdater:1189 - Updater busy. Cannot search thirdparties
2023-07-28 08:46:04,162 [INFO] ThirdPartyUpdaterWithRetryManager:96 - Updater plugin is busy. [1/15]
2023-07-28 08:46:04,301 [ERROR] ServerAccessManage:1089 - Problem, file not found on Server
2023-07-28 08:46:04,373 [INFO] ServerAccessManage:473 - Download File STMicroelectronics.X-CUBE-FREERTOS.pdsc
2023-07-28 08:46:04,436 [INFO] ServerAccessManage:473 - Download File STMicroelectronics.X-CUBE-GNSS1.pdsc
2023-07-28 08:46:04,719 [ERROR] ServerAccessManage:1089 - Problem, file not found on Server
2023-07-28 08:46:04,839 [ERROR] ServerAccessManage:1089 - Problem, file not found on Server
2023-07-28 08:46:04,962 [ERROR] ServerAccessManage:1089 - Problem, file not found on Server
2023-07-28 08:46:05,081 [ERROR] ServerAccessManage:1089 - Problem, file not found on Server
2023-07-28 08:46:05,305 [ERROR] ServerAccessManage:1089 - Problem, file not found on Server
2023-07-28 08:46:05,427 [ERROR] ServerAccessManage:1089 - Problem, file not found on Server
2023-07-28 08:46:05,445 [INFO] ServerAccessManage:473 - Download File STMicroelectronics.X-CUBE-ISPU.pdsc
2023-07-28 08:46:05,511 [INFO] ServerAccessManage:473 - Download File STMicroelectronics.X-CUBE-MEMS1.pdsc
2023-07-28 08:46:06,016 [INFO] ServerAccessManage:473 - Download File STMicroelectronics.X-CUBE-NFC4.pdsc
2023-07-28 08:46:06,296 [INFO] ServerAccessManage:473 - Download File STMicroelectronics.X-CUBE-NFC7.pdsc
2023-07-28 08:46:06,358 [INFO] ServerAccessManage:473 - Download File STMicroelectronics.X-CUBE-SFXS2LP1.pdsc
2023-07-28 08:46:06,456 [INFO] ServerAccessManage:473 - Download File STMicroelectronics.X-CUBE-SUBG2.pdsc
2023-07-28 08:46:06,660 [INFO] ServerAccessManage:473 - Download File STMicroelectronics.X-CUBE-SMBUS.pdsc
2023-07-28 08:46:06,813 [ERROR] ServerAccessManage:1089 - Problem, file not found on Server
2023-07-28 08:46:06,834 [INFO] ServerAccessManage:473 - Download File STMicroelectronics.X-CUBE-TOF1.pdsc
2023-07-28 08:46:07,108 [ERROR] ServerAccessManage:1089 - Problem, file not found on Server
2023-07-28 08:46:07,144 [INFO] ServerAccessManage:473 - Download File STMicroelectronics.X-CUBE-TOUCHGFX.pdsc
2023-07-28 08:46:07,163 [WARN] MainUpdater:1189 - Updater busy. Cannot search thirdparties
2023-07-28 08:46:07,164 [INFO] ThirdPartyUpdaterWithRetryManager:96 - Updater plugin is busy. [2/15]
2023-07-28 08:46:07,484 [INFO] ServerAccessManage:473 - Download File STMicroelectronics.X-CUBE-ALGOBUILD.pdsc
2023-07-28 08:46:07,616 [INFO] ServerAccessManage:473 - Download File STMicroelectronics.X-CUBE-AZRTOS-H7.pdsc
2023-07-28 08:46:07,821 [INFO] ServerAccessManage:473 - Download File STMicroelectronics.X-CUBE-AZRTOS-F4.pdsc
2023-07-28 08:46:07,958 [INFO] ServerAccessManage:473 - Download File STMicroelectronics.X-CUBE-AZRTOS-F7.pdsc
2023-07-28 08:46:08,105 [INFO] ServerAccessManage:473 - Download File STMicroelectronics.X-CUBE-AZRTOS-L4.pdsc
2023-07-28 08:46:08,241 [INFO] ServerAccessManage:473 - Download File STMicroelectronics.X-CUBE-AZRTOS-L5.pdsc
2023-07-28 08:46:08,369 [INFO] ServerAccessManage:473 - Download File STMicroelectronics.X-CUBE-AZRTOS-G0.pdsc
2023-07-28 08:46:08,501 [INFO] ServerAccessManage:473 - Download File STMicroelectronics.X-CUBE-AZRTOS-G4.pdsc
2023-07-28 08:46:08,599 [INFO] ServerAccessManage:473 - Download File STMicroelectronics.X-CUBE-AZRTOS-WB.pdsc
2023-07-28 08:46:08,671 [INFO] ServerAccessManage:473 - Download File STMicroelectronics.X-CUBE-AZRTOS-WL.pdsc
2023-07-28 08:46:09,402 [INFO] ServerAccessManage:473 - Download File wolfSSL.I-CUBE-wolfSSL.pdsc
2023-07-28 08:46:10,106 [INFO] WebApp:157 - Instantiating new browser for Auth
2023-07-28 08:46:10,164 [WARN] MainUpdater:1189 - Updater busy. Cannot search thirdparties
2023-07-28 08:46:10,164 [INFO] ThirdPartyUpdaterWithRetryManager:96 - Updater plugin is busy. [3/15]
2023-07-28 08:46:10,656 [INFO] WebApp:753 - Register for checkConnection events
2023-07-28 08:46:10,656 [INFO] WebApp:390 - Apply proxy settings
2023-07-28 08:46:10,656 [INFO] WebApp:475 - Chromium requires no authentication
2023-07-28 08:46:10,662 [INFO] WebApp:418 - Direct internet connection detected
2023-07-28 08:46:10,848 [INFO] WebApp:188 - Starting web application
2023-07-28 08:46:10,849 [INFO] WebApp:520 - Web application path used jar:file:/Applications/STMicroelectronics/STM32CubeMX.app/Contents/Resources/STM32CubeMX!/db/plugins/mcufinder/reactClient1/index.html
2023-07-28 08:46:13,099 [ERROR] ServerAccessManage:1089 - Problem, file not found on Server
2023-07-28 08:46:13,165 [WARN] MainUpdater:1189 - Updater busy. Cannot search thirdparties
2023-07-28 08:46:13,166 [INFO] ThirdPartyUpdaterWithRetryManager:96 - Updater plugin is busy. [4/15]
2023-07-28 08:46:13,600 [ERROR] ServerAccessManage:1089 - Problem, file not found on Server
2023-07-28 08:46:14,112 [ERROR] ServerAccessManage:1089 - Problem, file not found on Server
2023-07-28 08:46:14,805 [ERROR] ServerAccessManage:1096 - Problem, Http access forbiden
2023-07-28 08:46:14,806 [ERROR] ServerAccessManage:651 - Problem, Http access forbiden : RoweBots.I-CUBE-UNISONRTOS.pdsc.
2023-07-28 08:46:15,044 [INFO] ServerAccessManage:473 - Download File SEGGER.I-CUBE-embOS.pdsc
2023-07-28 08:46:15,606 [INFO] ServerAccessManage:473 - Download File portGmbH.I-Cube-SoM-uGOAL.pdsc
2023-07-28 08:46:16,039 [ERROR] ServerAccessManage:1089 - Problem, file not found on Server
2023-07-28 08:46:16,081 [ERROR] ServerAccessManage:1089 - Problem, file not found on Server
2023-07-28 08:46:16,123 [ERROR] ServerAccessManage:1089 - Problem, file not found on Server
2023-07-28 08:46:16,166 [WARN] MainUpdater:1189 - Updater busy. Cannot search thirdparties
2023-07-28 08:46:16,166 [INFO] ThirdPartyUpdaterWithRetryManager:96 - Updater plugin is busy. [5/15]
2023-07-28 08:46:16,375 [INFO] ServerAccessManage:473 - Download File emotas.I-CUBE-CANOPEN.pdsc
2023-07-28 08:46:17,492 [INFO] ServerAccessManage:473 - Download File WES.I-CUBE-Cesium.pdsc
2023-07-28 08:46:19,167 [WARN] MainUpdater:1189 - Updater busy. Cannot search thirdparties
2023-07-28 08:46:19,168 [INFO] ThirdPartyUpdaterWithRetryManager:96 - Updater plugin is busy. [6/15]
2023-07-28 08:46:19,744 [ERROR] ServerAccessManage:1089 - Problem, file not found on Server
2023-07-28 08:46:20,507 [ERROR] ServerAccessManage:1089 - Problem, file not found on Server
2023-07-28 08:46:20,581 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.FP-ATR-ASTRA1.2.0.0
2023-07-28 08:46:20,583 [WARN] CheckServerUpdateThread:151 - Open CheckUpdateFile Fail
2023-07-28 08:46:20,588 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.FP-ATR-SIGFOX1.3.2.0
2023-07-28 08:46:20,596 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.FP-SNS-FLIGHT1.5.0.2
2023-07-28 08:46:20,605 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.FP-SNS-MOTENV1.4.3.2
2023-07-28 08:46:20,615 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-AI.8.0.1
2023-07-28 08:46:20,623 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-ALS.1.0.1
2023-07-28 08:46:20,632 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-BLE1.6.2.4
2023-07-28 08:46:20,638 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-BLE2.3.3.0
2023-07-28 08:46:20,653 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-BLEMGR.2.0.0
2023-07-28 08:46:20,667 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-DISPLAY.3.0.0
2023-07-28 08:46:20,683 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-EEPRMA1.4.1.0
2023-07-28 08:46:20,692 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-FREERTOS.1.0.1
2023-07-28 08:46:20,697 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-GNSS1.6.0.0
2023-07-28 08:46:20,704 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-ISPU.1.1.0
2023-07-28 08:46:20,719 [INFO] CheckServerUpdateThread:120 - End of CheckServer Thread
2023-07-28 08:46:20,777 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-MEMS1.9.6.0
2023-07-28 08:46:20,964 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-NFC4.3.0.0
2023-07-28 08:46:20,969 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-NFC7.1.0.1
2023-07-28 08:46:20,975 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-SFXS2LP1.4.0.0
2023-07-28 08:46:20,984 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-SUBG2.5.0.0
2023-07-28 08:46:20,992 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-SMBUS.2.1.0
2023-07-28 08:46:20,999 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-TOF1.3.3.1
2023-07-28 08:46:21,012 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-TOUCHGFX.4.22.0
2023-07-28 08:46:21,017 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-ALGOBUILD.1.3.0
2023-07-28 08:46:21,033 [WARN] ConditionMgr:438 - getConditionDescription Invalid condition id : UX DEVICE CLASS RTOS Condition cause : null
2023-07-28 08:46:21,037 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-AZRTOS-H7.3.1.0
2023-07-28 08:46:21,039 [WARN] ConditionMgr:1039 - genDependencies : Invalid condition id : UX DEVICE CLASS RTOS Condition cause : null
2023-07-28 08:46:21,040 [WARN] ConditionMgr:1039 - genDependencies : Invalid condition id : UX DEVICE CLASS RTOS Condition cause : null
2023-07-28 08:46:21,041 [WARN] ConditionMgr:1039 - genDependencies : Invalid condition id : UX DEVICE CLASS RTOS Condition cause : null
2023-07-28 08:46:21,059 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-AZRTOS-F4.1.1.0
dimmorpheus
Log (part 2):
Spoiler
dimmorpheus
Log (part 3):
Spoiler
2023-07-28 08:46:21,074 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-AZRTOS-F7.1.1.0
2023-07-28 08:46:21,092 [WARN] ConditionMgr:438 - getConditionDescription Invalid condition id : LAN8742 Phy interface Condition cause : null
2023-07-28 08:46:21,093 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-AZRTOS-L4.2.0.0
2023-07-28 08:46:21,094 [WARN] ConditionMgr:1039 - genDependencies : Invalid condition id : LAN8742 Phy interface Condition cause : null
2023-07-28 08:46:21,107 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-AZRTOS-L5.1.1.0
2023-07-28 08:46:21,121 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-AZRTOS-G0.1.1.0
2023-07-28 08:46:21,134 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-AZRTOS-G4.2.0.0
2023-07-28 08:46:21,156 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-AZRTOS-WB.1.1.0
2023-07-28 08:46:21,171 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-AZRTOS-WL.2.0.0
2023-07-28 08:46:21,175 [WARN] PackLoader:240 - Cannot read IP mode file for wolfSSL.I-CUBE-wolfSSL.5.6.3
2023-07-28 08:46:21,205 [WARN] PackLoader:240 - Cannot read IP mode file for SEGGER.I-CUBE-embOS.1.3.1
2023-07-28 08:46:21,258 [WARN] PackLoader:240 - Cannot read IP mode file for portGmbH.I-Cube-SoM-uGOAL.1.1.0
2023-07-28 08:46:21,262 [WARN] PackLoader:240 - Cannot read IP mode file for emotas.I-CUBE-CANOPEN.1.3.0
2023-07-28 08:46:21,266 [WARN] PackLoader:240 - Cannot read IP mode file for WES.I-CUBE-Cesium.1.3.0
2023-07-28 08:46:21,266 [INFO] PopulateThirdPartyThread:66 - Ending populate Thread
2023-07-28 08:46:21,268 [INFO] ThirdParty:1030 - CMSIS Pack Vendor :STMicroelectronics X-CUBE-ISPU 1.1.0
2023-07-28 08:46:21,269 [INFO] ThirdParty:1030 - CMSIS Pack Vendor :STMicroelectronics X-CUBE-DISPLAY 3.0.0
2023-07-28 08:46:21,269 [INFO] ThirdParty:1030 - CMSIS Pack Vendor :STMicroelectronics X-CUBE-GNSS1 6.0.0
2023-07-28 08:46:21,269 [INFO] ThirdParty:1030 - CMSIS Pack Vendor :STMicroelectronics X-CUBE-AZRTOS-F4 1.1.0
2023-07-28 08:46:21,269 [INFO] ThirdParty:1030 - CMSIS Pack Vendor :STMicroelectronics FP-ATR-SIGFOX1 3.2.0
2023-07-28 08:46:21,269 [INFO] ThirdParty:1030 - CMSIS Pack Vendor :wolfSSL I-CUBE-wolfSSL 5.6.3
2023-07-28 08:46:21,269 [INFO] ThirdParty:1030 - CMSIS Pack Vendor :STMicroelectronics X-CUBE-SMBUS 2.1.0
2023-07-28 08:46:21,270 [INFO] ThirdParty:1030 - CMSIS Pack Vendor :emotas I-CUBE-CANOPEN 1.3.0
2023-07-28 08:46:21,270 [INFO] ThirdParty:1030 - CMSIS Pack Vendor :STMicroelectronics X-CUBE-FREERTOS 1.0.1
2023-07-28 08:46:21,270 [INFO] ThirdParty:1030 - CMSIS Pack Vendor :STMicroelectronics X-CUBE-NFC7 1.0.1
2023-07-28 08:46:21,270 [INFO] ThirdParty:1030 - CMSIS Pack Vendor :STMicroelectronics X-CUBE-TOUCHGFX 4.22.0
2023-07-28 08:46:21,270 [INFO] ThirdParty:1030 - CMSIS Pack Vendor :STMicroelectronics X-CUBE-AZRTOS-F7 1.1.0
2023-07-28 08:46:21,270 [INFO] ThirdParty:1030 - CMSIS Pack Vendor :STMicroelectronics X-CUBE-ALS 1.0.1
2023-07-28 08:46:21,270 [INFO] ThirdParty:1030 - CMSIS Pack Vendor :STMicroelectronics X-CUBE-EEPRMA1 4.1.0
2023-07-28 08:46:21,270 [INFO] ThirdParty:1030 - CMSIS Pack Vendor :portGmbH I-Cube-SoM-uGOAL 1.1.0
2023-07-28 08:46:21,270 [INFO] ThirdParty:1030 - CMSIS Pack Vendor :STMicroelectronics X-CUBE-MEMS1 9.6.0
2023-07-28 08:46:21,271 [INFO] ThirdParty:1030 - CMSIS Pack Vendor :STMicroelectronics X-CUBE-AZRTOS-WB 1.1.0
2023-07-28 08:46:21,271 [INFO] ThirdParty:1030 - CMSIS Pack Vendor :STMicroelectronics FP-SNS-MOTENV1 4.3.2
2023-07-28 08:46:21,271 [INFO] ThirdParty:1030 - CMSIS Pack Vendor :STMicroelectronics X-CUBE-ALGOBUILD 1.3.0
2023-07-28 08:46:21,271 [INFO] ThirdParty:1030 - CMSIS Pack Vendor :STMicroelectronics X-CUBE-AZRTOS-WL 2.0.0
2023-07-28 08:46:21,271 [INFO] ThirdParty:1030 - CMSIS Pack Vendor :SEGGER I-CUBE-embOS 1.3.1
2023-07-28 08:46:21,271 [INFO] ThirdParty:1030 - CMSIS Pack Vendor :STMicroelectronics X-CUBE-BLE1 6.2.4
2023-07-28 08:46:21,271 [INFO] ThirdParty:1030 - CMSIS Pack Vendor :STMicroelectronics X-CUBE-AZRTOS-L5 1.1.0
2023-07-28 08:46:21,271 [INFO] ThirdParty:1030 - CMSIS Pack Vendor :STMicroelectronics X-CUBE-AZRTOS-G0 1.1.0
2023-07-28 08:46:21,272 [INFO] ThirdParty:1030 - CMSIS Pack Vendor :STMicroelectronics X-CUBE-AI 8.0.1
2023-07-28 08:46:21,272 [INFO] ThirdParty:1030 - CMSIS Pack Vendor :STMicroelectronics X-CUBE-BLEMGR 2.0.0
2023-07-28 08:46:21,272 [INFO] ThirdParty:1030 - CMSIS Pack Vendor :STMicroelectronics X-CUBE-NFC4 3.0.0
2023-07-28 08:46:21,272 [INFO] ThirdParty:1030 - CMSIS Pack Vendor :STMicroelectronics X-CUBE-SUBG2 5.0.0
2023-07-28 08:46:21,272 [INFO] ThirdParty:1030 - CMSIS Pack Vendor :STMicroelectronics X-CUBE-AZRTOS-L4 2.0.0
2023-07-28 08:46:21,272 [INFO] ThirdParty:1030 - CMSIS Pack Vendor :STMicroelectronics FP-ATR-ASTRA1 2.0.0
2023-07-28 08:46:21,272 [INFO] ThirdParty:1030 - CMSIS Pack Vendor :WES I-CUBE-Cesium 1.3.0
2023-07-28 08:46:21,272 [INFO] ThirdParty:1030 - CMSIS Pack Vendor :STMicroelectronics X-CUBE-SFXS2LP1 4.0.0
2023-07-28 08:46:21,272 [INFO] ThirdParty:1030 - CMSIS Pack Vendor :STMicroelectronics FP-SNS-FLIGHT1 5.0.2
2023-07-28 08:46:21,272 [INFO] ThirdParty:1030 - CMSIS Pack Vendor :STMicroelectronics X-CUBE-BLE2 3.3.0
2023-07-28 08:46:21,273 [INFO] ThirdParty:1030 - CMSIS Pack Vendor :STMicroelectronics X-CUBE-TOF1 3.3.1
2023-07-28 08:46:21,273 [INFO] ThirdParty:1030 - CMSIS Pack Vendor :STMicroelectronics X-CUBE-AZRTOS-G4 2.0.0
2023-07-28 08:46:21,273 [INFO] ThirdParty:1030 - CMSIS Pack Vendor :STMicroelectronics X-CUBE-AZRTOS-H7 3.1.0
2023-07-28 08:46:21,273 [INFO] LoadServerUpdatesThread:373 - End of LoadServerUpdate Thread
2023-07-28 08:46:22,270 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-SMBUS.2.1.0
2023-07-28 08:46:22,283 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-AZRTOS-F7.1.1.0
2023-07-28 08:46:22,288 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.FP-SNS-MOTENV1.4.3.2
2023-07-28 08:46:22,292 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-BLE1.6.2.4
2023-07-28 08:46:22,295 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.FP-SNS-FLIGHT1.5.0.2
2023-07-28 08:46:22,300 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-DISPLAY.3.0.0
2023-07-28 08:46:22,306 [WARN] PackLoader:240 - Cannot read IP mode file for emotas.I-CUBE-CANOPEN.1.3.0
2023-07-28 08:46:22,309 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-TOUCHGFX.4.22.0
2023-07-28 08:46:22,318 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-AZRTOS-WL.2.0.0
2023-07-28 08:46:22,323 [WARN] PackLoader:240 - Cannot read IP mode file for WES.I-CUBE-Cesium.1.3.0
2023-07-28 08:46:22,327 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-BLE2.3.3.0
2023-07-28 08:46:22,331 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-ALGOBUILD.1.3.0
2023-07-28 08:46:22,344 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-AZRTOS-G0.1.1.0
2023-07-28 08:46:22,350 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-NFC4.3.0.0
2023-07-28 08:46:22,353 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.FP-ATR-SIGFOX1.3.2.0
2023-07-28 08:46:22,376 [WARN] PackLoader:240 - Cannot read IP mode file for SEGGER.I-CUBE-embOS.1.3.1
2023-07-28 08:46:22,418 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-GNSS1.6.0.0
2023-07-28 08:46:22,429 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-AZRTOS-F4.1.1.0
2023-07-28 08:46:22,433 [WARN] PackLoader:240 - Cannot read IP mode file for wolfSSL.I-CUBE-wolfSSL.5.6.3
2023-07-28 08:46:22,463 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-MEMS1.9.6.0
2023-07-28 08:46:22,589 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-BLEMGR.2.0.0
2023-07-28 08:46:22,602 [WARN] ConditionMgr:438 - getConditionDescription Invalid condition id : UX DEVICE CLASS RTOS Condition cause : null
2023-07-28 08:46:22,603 [WARN] ConditionMgr:438 - getConditionDescription Invalid condition id : UX DEVICE CLASS RTOS Condition cause : null
2023-07-28 08:46:22,605 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-AZRTOS-H7.3.1.0
2023-07-28 08:46:22,606 [WARN] ConditionMgr:1039 - genDependencies : Invalid condition id : UX DEVICE CLASS RTOS Condition cause : null
2023-07-28 08:46:22,607 [WARN] ConditionMgr:1039 - genDependencies : Invalid condition id : UX DEVICE CLASS RTOS Condition cause : null
2023-07-28 08:46:22,608 [WARN] ConditionMgr:1039 - genDependencies : Invalid condition id : UX DEVICE CLASS RTOS Condition cause : null
2023-07-28 08:46:22,613 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-NFC7.1.0.1
2023-07-28 08:46:22,623 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-EEPRMA1.4.1.0
2023-07-28 08:46:22,638 [WARN] ConditionMgr:438 - getConditionDescription Invalid condition id : LAN8742 Phy interface Condition cause : null
2023-07-28 08:46:22,639 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-AZRTOS-L4.2.0.0
2023-07-28 08:46:22,640 [WARN] ConditionMgr:1039 - genDependencies : Invalid condition id : LAN8742 Phy interface Condition cause : null
2023-07-28 08:46:22,641 [WARN] ConditionMgr:1039 - genDependencies : Invalid condition id : LAN8742 Phy interface Condition cause : null
2023-07-28 08:46:22,646 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-SFXS2LP1.4.0.0
2023-07-28 08:46:22,649 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-ISPU.1.1.0
2023-07-28 08:46:22,654 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-FREERTOS.1.0.1
2023-07-28 08:46:22,666 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-AZRTOS-L5.1.1.0
2023-07-28 08:46:22,670 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-AI.8.0.1
2023-07-28 08:46:22,677 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-SUBG2.5.0.0
2023-07-28 08:46:22,691 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-TOF1.3.3.1
2023-07-28 08:46:22,709 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-AZRTOS-G4.2.0.0
2023-07-28 08:46:22,714 [WARN] PackLoader:240 - Cannot read IP mode file for portGmbH.I-Cube-SoM-uGOAL.1.1.0
2023-07-28 08:46:22,717 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-ALS.1.0.1
2023-07-28 08:46:22,728 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-AZRTOS-WB.1.1.0
2023-07-28 08:46:22,734 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.FP-ATR-ASTRA1.2.0.0
2023-07-28 08:46:22,736 [INFO] ThirdParty:978 - Integrity check success = true
2023-07-28 08:46:22,736 [INFO] IntegrityCheckThread:100 - exiting critical section [integrity check]
2023-07-28 08:46:22,736 [INFO] IntegrityCheckThread:103 - End integrity checks thread
2023-07-28 08:46:45,393 [INFO] LoadServerUpdatesThread:373 - End of LoadServerUpdate Thread
2023-07-28 08:46:45,516 [INFO] WebApp:390 - Apply proxy settings
2023-07-28 08:46:45,517 [INFO] WebApp:475 - Chromium requires no authentication
2023-07-28 08:46:45,517 [INFO] WebApp:418 - Direct internet connection detected
2023-07-28 08:46:45,517 [INFO] WebApp:312 - Starting web application
2023-07-28 08:46:45,517 [INFO] WebApp:520 - Web application path used jar:file:/Applications/STMicroelectronics/STM32CubeMX.app/Contents/Resources/STM32CubeMX!/db/plugins/mcufinder/reactClient1/index.html
2023-07-28 08:46:45,539 [INFO] UserAuth:393 - Internet connection configuration mode: 1
2023-07-28 08:46:45,561 [INFO] CheckServerUpdateThread:120 - End of CheckServer Thread
2023-07-28 08:46:51,387 [ERROR] WebApp:339 - JxBrowser engine crashed! Exit code: 137
Sorry, I haven't seen that 2nd part of the log isn't posted.
Please see it below:
Spoiler
Log [part 2]
Spoiler
Hello  again @dimmorpheus
In order to push further the investigation could you please provide :
- OS (name + version)
- Chromium crash reports contained in files with the *.dmp extension located under
o Windows %localappdata% JxBrowser 7.30.2 CrashReports
o macOS $HOME/Library/Application Support/JxBrowser/7.30.2/CrashReports
o Linux $HOME/. config/jxbrowser/7.30.2/crash-reports
- Any additional information concerning the hardware such as
o CPU: brand, model, clock speed, number of cores, etc.
o RAM: capacity, type, frequency, etc.
o HDD or SSD: capacity, rotation speed, interface, etc.
o GPU: brand, model, video memory, etc
Thx
Ghofrane
JxBrowser - so that's where the additional +78 MB of ZIP file came with the CubeMX v6.9.0. Nice, now we also have a Chromium browser packed in just because of the "authentication", which, according to ST, is not and unnecessary nuisance and tracking, but instead makes "users enjoy a more cohesive experience".
