STM32CubeMX 6.13.0 - Application Structure is Basic and grayed out
Jack3
Senior II
In STM32CubeMX 6.13.0 - Application Structure is Basic and gray.
I solved it by editing the ioc file, it remains gray, but at least "Advanced" is selected and the code is generated accordingly.
I changed
ProjectManager.MainLocation=Src
to
ProjectManager.MainLocation=Core/Src
Is it intended to work like this?
3 REPLIES 3
STTwo-32
Hello @Jack3
Could you please give more details about your original problem. So we may can help you.
Best Regards.
STTwo-32
Thank you for looking in it.
I hereby post the ioc files and screenshots.
"Basic" grayed, can't select "Advanced"
"Advanced" grayed, can't select "Basic"
When comparing the ioc files, one can see how to alter the choice.
Why doesn't STM32CubeMX allow it?
But I just figured that after a save as... I can select it!
But when reopening it, I can't again.
What's the idea behind it?
I've escalated this request to the concerned team to review the possibility to implement this on the Future (under internal ticket number 203793).
Best Regards.
STTwo-32
