STM32CubeIDE & MX integrated
‎2023-09-03 3:53 AM
- Labels:
STM32CubeMX
‎2023-09-04 2:32 PM
I will continue my work with release 1.12.1 while waiting for the solution to the problem of release 1.13.1.
Thanks for your help.
‎2023-09-03 4:45 AM - edited ‎2023-09-03 4:48 AM
‎2023-09-03 7:54 AM
Thanks for the reply.
I've already uninstalled with a purge and manually deleted the rest, reinstalled three times without success.
Now I try to uninstall ALL STM32 packages.
I hope for better luck.
Thank you
‎2023-09-03 7:58 AM - edited ‎2023-09-04 5:27 PM
Uninstall all the STM32 SW and packages and than reinstall them well be a good idea I guess.
Best regards.
II
‎2023-09-03 2:26 PM
Now it's worse than before. I can't even accept the license...
‎2023-09-03 2:31 PM
I'm tired of this situation. Hours wasted for nothing!!
‎2023-09-03 2:50 PM
Make sure to install the tools with administrator privileges, "Run as Administrator".
Make sure that your directory path (repository name) doesn't contain special characters.
Best regards.
II
‎2023-09-03 3:18 PM
After the 8th uninstall and install (see image)
‎2023-09-03 3:24 PM - edited ‎2023-09-04 5:27 PM
Hope that works fine.
Best regards.
II
‎2023-09-04 6:06 AM
Don't work again.
I installed version 1.10.1 and it works fine. I want to try with 1.12.1
