2023-05-03 05:16 AM - edited 2023-11-20 06:37 AM
By copying project for sake of duplicating them, the subproject cubeMX .ioc file will no longer becomming open.
Also renaming cubeIDE projects will cause anomaly. In front of their name, something tells the folder of project have different name. In standard Eclipse CDT everything done without artifact after renming projects.
2023-05-03 07:51 AM - edited 2023-11-20 06:37 AM
Hello @SeyyedMohammad
I tried to reproduce the issue mentioned above by following those steps
1- Created a project using CubeMX 6.8.1.
2- Copy this project in order to duplicate it .
3- Open the two projects
==> both ioc files opened successfully , please check the screenshots
I will be waiting for your feedback .
Thx
Ghofrane
2023-05-05 12:52 PM
Hello @Ghofrane GSOURI
Sorry, I ment on cubeIDE. after copying project file in eclipse IDE. the .ioc file of project no longer works. The bug is on cubeIDE not the cubeMX.
2023-05-05 01:55 PM
You can easily do this; manually edit the project name in the ioc file and rename the ioc file itself.
2023-05-23 07:13 AM
Hi @Ghofrane GSOURI
Was my description, incomplete? If so tell me please.
2023-05-23 07:16 AM
Manually you can write full x86_64 OS, do it yourself, then! Thanks for workaround.
