2024-02-21 05:33 AM
i installed STM32 CubeMX 6.2.9 today. I tried to add software packages by clicking "help" -> "Manage embedded software packages", but nothing happens. Then i tried to log in using "myST" -> "Login", but again nothing happens and i can not log in. I tried using ALT U and ALT L but it did not work.
I attached the log file of STM32CubeMX
Thanks,
Marisa
2024-02-21 05:49 AM
Hello @M_Ehe and welcome to the ST Community
Could you please update to the last version of CubeMX, CubeMX 6.10.0.
Best Regards.
STTwo-32
2024-02-21 05:49 AM
Best Regards.
STTwo-32
2024-02-21 06:35 AM
i installed the latest version and was able to log in & install software packages. However, it did not run from the start, but the problems haven been caused by our IT security system so i could find a solution/workaround
Thank you very much
Marisa
