PWM output on Timer3 Ch1
‎2019-05-28 9:04 AM
I've my LCD backlight control on STM32F429 pin PB4, and as a digital output it was fine. I chose this pin because it can be configured as a PWM output.
I've set up TIM3 Ch1 in CubeMX. I just want a free-running PWM with a dynamically configurable duty cycle, so I can set my backlight to 'bright', 'medium' or 'dim' settings.
I'm getting no signal on PB4, it is just sitting high.
Did I miss something? Is there an 'enable' or 'start' instruction I need to add?
‎2019-05-29 2:21 AM
How do I flag this thread as "answered"?
‎2019-05-30 5:51 AM
Click on "Select as Best" on the comment that you consider the more helpful one.
- « Previous
- 1
- 2
- Next »
