2015-01-12 2:38 AM
Hello all.
Bed path: java.io.FileNotFoundException: /home/krzysiek/STMicroelectronics/STM32Cube/STM32CubeMX/db/plugins/projectmanager\stm32tck.cfg (No such file or directory) at java.io.FileInputStream.open(Native Method) at java.io.FileInputStream.<init>(FileInputStream.java:146) at java.io.FileInputStream.<init>(FileInputStream.java:101) at java.io.FileReader.<init>(FileReader.java:58) at convertor.Convertor.getTplVer(Convertor.java:1152) at convertor.Convertor.setTemplates(Convertor.java:536) at convertor.Convertor.setDataPath(Convertor.java:1495) at com.st.microxplorer.plugins.projectmanager.model.ToolchainGenerator.setDllDataPath(ToolchainGenerator.java:116) at com.st.microxplorer.plugins.projectmanager.engine.ProjectBuilder.createToolChainFolders(ProjectBuilder.java:934) at com.st.microxplorer.plugins.projectmanager.engine.ProjectBuilder.createProject(ProjectBuilder.java:339) at com.st.microxplorer.plugins.projectmanager.engine.GenerateProjectThread.run(GenerateProjectThread.java:36) Project Generator version: 1.5.1 [Project Generator] Problem in the project generation java.io.FileNotFoundException: /home/krzysiek/STMicroelectronics/STM32Cube/STM32CubeMX/db/plugins/projectmanager\stm32tck.cfg (No such file or directory) at java.io.FileInputStream.open(Native Method) at java.io.FileInputStream.<init>(FileInputStream.java:146) at java.io.FileInputStream.<init>(FileInputStream.java:101) at java.io.FileReader.<init>(FileReader.java:58) at convertor.Convertor.getTplVer(Convertor.java:1152) at convertor.Convertor.setTemplates(Convertor.java:536) at convertor.Convertor.convert(Convertor.java:377) at convertor.Convertor.generate(Convertor.java:1476) at com.st.microxplorer.plugins.projectmanager.model.ToolchainGenerator.generate(ToolchainGenerator.java:53) at com.st.microxplorer.plugins.projectmanager.engine.ProjectBuilder.createToolChainFolders(ProjectBuilder.java:948) at com.st.microxplorer.plugins.projectmanager.engine.ProjectBuilder.createProject(ProjectBuilder.java:339) at com.st.microxplorer.plugins.projectmanager.engine.GenerateProjectThread.run(GenerateProjectThread.java:36) mx.scratch is deleted! Time for Generating toolchain IDE Files: 9mS. Error in Project Generation #linux #cubemx2015-02-16 5:56 AM
2016-02-09 3:16 AM
Dear user,
This issue is now fixed.
