Open Initialize all peripherals with their default Mode after selecting Yes, DEBUG without serial wire option
XIAOHE
Ghofrane GSOURI
Hello @�?�兵 何​
First let me thank you for posting.
Let's try this solution:
As shown in the screenshot , we need to eliminate the conflicts in order to make the "Trace asynchronous Sw" is the SWD (serial wire), works correctly
_legacyfs_online_stmicro_images_0693W00000bjaZ5QAI.pngAfter solving the conflicts :
I will be waiting for your feedback
Thx
Ghofrane
4 REPLIES 4
Pavel A.
Evangelist III
"Trace asynchronous Sw" is the SWD (serial wire), with additional SWO pin. So this is OK.
The red colored things are not relevant.
XIAOHE
@Pavel A.​ I understand what you mean, however, I exported to keil via GENERATE CODE and it will not work after burning to the development board in keil.
Ghofrane GSOURI
Hello @�?�兵 何​
Thx
Ghofrane
XIAOHE
@Ghofrane GSOURI​
Thank you very much indeed, the problem is solved!
