LwIP raw api with static IP and NUCLEO-F429ZI slow startup: It takes 15 seconds for the first ping.
PTiha
Hello!
I created a standard LwIP NO-OS project with static IP. Everything works perfectly, but it takes ~ 15 seconds for the first PING response.
After that the ping times ~1.4 ms.
I tried what happens when I disconnect the Ethernet cable and then reconnect it.
It took another 15 seconds to re-establish the connection (the first ping response arrived).
The MCU core clock is 168 MHz. SysTick is 1ms.
Why can this be?
4 REPLIES 4
Pavel A.
Evangelist III
This is likely because the example is set to use DHCP with lot of retries before falling back to a static address, and you don't have a DHCP server.
-- pa
PTiha
It should not send DHCP requests because the DHCP module is disabled.
PTiha
In the meantime I watched the communication between the NUCLEO and my developer notebook with Wireshark.
There isn't any DHCP requests from the NUCLEO.
I don't know what he's doing for 15 seconds.
J.Strom
Hi PTiha,
Did you solve the problem? I have the same problem. After link is up there is a delay of several seconds, then it works as expected. Also with DHCP disabled.
Johan
