2024-09-05 02:29 AM
2024-09-05 02:34 AM
Hello @ofsong and welcome to the community.
Do you have a proxy? if yes indeed you need to configure it in Help -> "Updater Settings" -> "Connection parameters"
Otherwise you can set it to "No Proxy"
2024-09-05 02:46 AM
Hello @ofsong
You can also refer to this article to understand how this works.
Best Regards.
STTwo-32
2024-09-05 02:46 AM
对我设置的无代理,然后登录一直显示这个
2024-09-05 03:36 AM
Try to restart CubeMX. If you are not using the last version, please update to your tool.
Best Regards.
STTwo-32
