STM32 Cube MX and IAR
- August 1, 2024
- 2 replies
- 1785 views
Hi All,
I am trying to run a code with NUCLEO-U575ZI-Q The tool chain/ IDE is EWARM but the unable to select the latest version of IAR(9.50) The option is available only until IAR version 8.5. When I select generate code and select open project the IAR version 8.5 IDE opens and I will not be able to debug the firmware
I am able to debug the run the firmware when I select open folder and run EWARM from latest version of IAR(9.50)
Is there a way to be able to see the latest version on STM Cube MX ?
