Initiate 2nd ADC Watchdog Help
2021-09-03 5:05 PM
I have two ADC channels that l am trying to configure to have their own ADC watchdog. Experimenting with the threshold values l can get the first watchdog to fire on each channel and it calls HAL_ADC_LevelOutOfWindowCallback() as needed. The second ADC watchdog does not fire at all. I didn't see it be initialized so l created some code that doesn't work. Can someone give insight on this? I eventually plan to use all three ADC watchdogs at once.
configuration:
static void MX_ADC3_Init(void)
/* USER CODE BEGIN ADC3_Init 0 */
/* USER CODE END ADC3_Init 0 */
ADC_AnalogWDGConfTypeDef AnalogWDGConfig = {0};
ADC_ChannelConfTypeDef sConfig = {0};
/* USER CODE BEGIN ADC3_Init 1 */
/* USER CODE END ADC3_Init 1 */
/** Common config
hadc3.Instance = ADC3;
hadc3.Init.ClockPrescaler = ADC_CLOCK_ASYNC_DIV4;
hadc3.Init.Resolution = ADC_RESOLUTION_16B;
hadc3.Init.ScanConvMode = ADC_SCAN_ENABLE;
hadc3.Init.EOCSelection = ADC_EOC_SINGLE_CONV;
hadc3.Init.LowPowerAutoWait = DISABLE;
hadc3.Init.ContinuousConvMode = DISABLE;
hadc3.Init.NbrOfConversion = 2;
hadc3.Init.DiscontinuousConvMode = DISABLE;
hadc3.Init.ExternalTrigConv = ADC_SOFTWARE_START;
hadc3.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
hadc3.Init.ConversionDataManagement = ADC_CONVERSIONDATA_DR;
hadc3.Init.Overrun = ADC_OVR_DATA_PRESERVED;
hadc3.Init.LeftBitShift = ADC_LEFTBITSHIFT_NONE;
hadc3.Init.OversamplingMode = DISABLE;
if (HAL_ADC_Init(&hadc3) != HAL_OK)
Error_Handler();
/** Configure Analog WatchDog 1
AnalogWDGConfig.WatchdogNumber = ADC_ANALOGWATCHDOG_1;
AnalogWDGConfig.WatchdogMode = ADC_ANALOGWATCHDOG_SINGLE_REG;
AnalogWDGConfig.Channel = ADC_CHANNEL_0;
AnalogWDGConfig.ITMode = ENABLE;
AnalogWDGConfig.HighThreshold = 67108863;
AnalogWDGConfig.LowThreshold = 0;
if (HAL_ADC_AnalogWDGConfig(&hadc3, &AnalogWDGConfig) != HAL_OK)
Error_Handler();
/** Configure Regular Channel
sConfig.Channel = ADC_CHANNEL_0;
sConfig.Rank = ADC_REGULAR_RANK_1;
sConfig.SamplingTime = ADC_SAMPLETIME_810CYCLES_5;
sConfig.SingleDiff = ADC_SINGLE_ENDED;
sConfig.OffsetNumber = ADC_OFFSET_NONE;
sConfig.Offset = 0;
sConfig.OffsetSignedSaturation = DISABLE;
if (HAL_ADC_ConfigChannel(&hadc3, &sConfig) != HAL_OK)
Error_Handler();
sConfig.Channel = ADC_CHANNEL_1;
sConfig.Rank = ADC_REGULAR_RANK_2;
Error_Handler();
/* USER CODE BEGIN ADC3_Init 2 */
/* Calibrate internal sensor on start up, Single-ended */
if (HAL_ADCEx_Calibration_Start(&hadc3,ADC_CALIB_OFFSET,ADC_SINGLE_ENDED) != HAL_OK)
Error_Handler();
/* USER CODE END ADC3_Init 2 */
code:
void watchdog_config_ether_arm(void){
AnalogWDGConfig.WatchdogNumber = ADC_ANALOGWATCHDOG_2;
AnalogWDGConfig.Channel = ADC_CHANNEL_1;
/* Configure threshold levels for ARM */
Error_Handler();
ADC
STM32CubeMX
STM32H7 Series
2021-09-15 9:53 AM
Hello @DWill.4 ,
Which CubeMx release are you using ?
Please share your ioc file for check.
Imen
Imen
2022-02-19 8:27 AM
Hi DWill4,
I am working with same issue, did you solve it ? If yes would be nice to share the solution.
if no;
You should be sure before configuring, there is no ADC conversion on going. Did you try with stop conversion function in the beginning of the second function?
/**** you should add stop Conversion****/
ADC_ConversionStop(&hadc3,ADC_REGULAR_INJECTED_GROUP);
Error_Handler();
