How to not generate a call to SystemClock_Config() function in Advance Settings?
DOsbo
Hi All,
I don't want STM32CubeMX to generate a call to SystemClock_Config() because the clocks are set up in a bootstrap that runs beforehand (due to XIP Flash). There is an option in the Advance Settings page to do it, but it's disabled. I cannot select the check box to not generate the call (the other check boxes work).
Is there a way to enable this feature?
Cheers,
David
Khouloud ZEMMELI
​Hello @DOsbo​ ,
It will be fixed in the next release.
Best Regards,
Khouloud.
Khouloud ZEMMELI
​Hello @DOsbo​ ,
Best Regards,
Khouloud.
Hi Khouloud,
Thank you for letting me know.
Cheers,
David
