How to enable USART driver in CubeMX?
‎2023-01-11 12:55 AM
The code generated by the STM32CubeMX is using the UART rather than the USART.
How do we generate the code using the USART driver lib via the CubeMX?
- Labels:
STM32CubeMX
UART-USART
‎2023-01-11 1:35 AM
Hi @Community member​
USART1, USART2, ... and/or UART4 or UART5, ... are instances of peripherals, able to achieve UART/USART communications.
Usually, USARTx instances are able to handle :
- UART comms : Asynchronous communication, no CLK signal
- USART comms : Synchronous, based on a CLK signal
while UARTy instances only handle :
So depending on what type of communication you want to handle, you need to select the appropriate type in CubeMx configuration :
"Asynchronous" => Use of HAL UART API, UART comm type
"Synchronous" => Use of HAL USART API, USART comm type
Hope this answers your question
‎2023-01-11 1:01 AM
Using the STM32L412 with the latest CubMx and Lib.
‎2023-01-11 1:25 AM
It's the same driver for both types
TimerCallback tutorial! | UART and DMA Idle with multiple UART instances tutorial!
‎2023-01-11 1:35 AM
‎2023-01-11 6:14 AM
Thanks. Got it. That mean the USART only be used when the synchronous mode selected. If the only asynchronous mode used, the CubeMX will only use the UART lib.
