How assert_param macro work
SS.Sagar
Posted on May 29, 2016 at 09:50
I m using cubemx for stacks. In files i foundassert_param is used for parameter checking. I don't understand how it is work. Here is syntax and use of that.
#define assert_param(expr) ((void)0)
assert_param(IS_UART_WORD_LENGTH(huart->Init.WordLength));
what will happen in both cases like
IS_UART_WORD_LENGTH returns 0 and 1.
#printf #assert #!cubemx #cubemx #debug
1 REPLY 1
Walid FTITI_O
Senior II
Posted on May 30, 2016 at 13:02
Hi hobb.epy,
assert_param is used to check that a parameter that is passed to a firmware library function is in the valid range of values. Each call to assert_param uses another macro that checks the parameter is in that range. If it is in range, then assert_param does nothing. If it is a bad value, then assert_failed is called with the filename and line number.
The assert_param function is disabled by default, and can be enabled by uncommenting the correspondent macro ( for example in Hal library , in stm32fxx_hal_conf.h :
/* #define USE_FULL_ASSERT    1 */ )
-Hannibal-
