HAL & STM32CubeMx
‎2021-10-31 1:11 PM
I will be working with some STM32F4 processors soon and so I am doing some reading ahead. What I am not clear on is if I use HAL to setup I/O or peripherals do I need to use STMCubeMX to set up the pins?
Can STMCubeMX (pin editor?) be opened from IDE?
MaryK
‎2021-10-31 2:20 PM
No, STM32CubeMX generates code that uses HAL, but you can use HAL without using the CubeMX generated code.
Yes, STM32CubeMX is integrated within STM32CubeIDE.
‎2021-10-31 2:20 PM
