FreeRtos V2 is incorrectly compiled in the compiler version 6
WeiGuo
FreeRtos V2 generates errors in compiler version 6. May I ask when this problem can be solved? Currently, this problem can be solved by porting the portmacro.h and port.c files, but you need to report each time you update the package version. Very troublesome
1 REPLY 1
STTwo-32
Hello @WeiGuo
Could you please give more details about the error that you are facing, in what IDE, what versions, what MCU you are using ?
Best Regards.
STTwo-32
