[CubeMX regression]Failed to generate code with 4.22.1
‎2017-09-12 11:46 PM
The new CubeMX 4.22.1 fails to generate code (and hangs on generation) for a STM32 workbench project which has been successfully generated with the previous versions.
Here is the command line output from the problem:
I am using Linux please see the ioc file attached. The error also occurs when generating blank project.
#bug #regression #cubemx-4.22Solved! Go to Solution.
Bug-report
STM32CubeMX
‎2017-09-15 4:12 AM
This issue only happened with an updated 4.22.1 CubeMX. After reinstallation it works fine.
‎2017-09-15 4:12 AM
