cubeMX Pin user label problem
Arnold Bischof
Posted on November 10, 2016 at 16:01
Pin user label disappears when I change the pin function in the cubeMX GUI. This is not an expected behavior, since the already given name of the pin has not changed.
#cubemx
10 REPLIES 10
Posted on December 07, 2017 at 19:35
For ST: Here's the issue. I have a bunch of pins with names that are on ADC1. To do a multi-channel simultaneous conversion, some of these pins are switched over to ADC2. What is the effect? Anybody? Craig Reed? Yes, correct, all of your labels are removed.
There is a quick (relative) way to put them back. If you go into the Configuration/ADC2 widget, under GPIO Settings, you can put the labels back in without a lot of clicking.  (yes this works for other subunits, give it a try)  But the preferred response would be to NOT scrub the labels.
Andrei
