CubeMX code generation overwrites linker library options !!
Stefano.Patassa
Hi, i'm running STM32CubeIDE 1.8.
I have a project with some libraries defined in the linker tab.
When i regenerate the code using CubeMX all the linker tab is wiped out to default values...
There is a way to overcome this?
Thanks!!
1 REPLY 1
Javier1
Principal
I use with modified linker.ld scripts and i never had the issue youre describing.
What do you mean with "linker tab"
we dont need to firmware by ourselves, lets talk
