2021-06-15 08:27 AM
I use user constants in projects entered in CubeMX window. I found two isues with latest MX.
2021-06-16 12:53 AM
Hello @MM..1
Thanks for your post,
I'll check the problem then I'll get back to you.
Khouloud
2021-06-16 09:12 AM
Hi again @MM..1 ,
You're right, I confirm the first issue using your ioc file (thanks for providing it, it helped me to reproduce the issue 🙂 ).
For the Second one, I cannot reproduce it, the code is well generated as configured in the ioc:
VidCfg.PacketSize = PACKSIZE;
With private define under main.h:
#define PACKSIZE 640
So, can you please provide me more details about the problem?
First issue will be fixed, thanks again for bringing this problem to our attention and for your contribution.
Khouloud
2021-07-10 07:52 AM
Hi KZ
i mean this and yes when ignore this code is generated ok
and please change this portal for i can CTRL V screenshots here. This strange upload system is annoyyyy
2021-08-13 01:03 AM
Hello @MM..1
Sorry for the delay,
Could you please check with the latest CubeIDE version?
I'll be waiting for your feedback,
Thanks, Khouloud
2021-08-16 06:03 AM
2021-08-17 01:38 AM
Hi again @MM..1 ,
Sorry for the misunderstanding, I thought the problem is linked to the generated code, otherwise, you're right, I can reproduce the issue shared in the image above using your ioc file, it will be fixed.
Thank you for your contribution 🙂
Khouloud
