2018-01-31 2:06 AM
CubeMx 4.24.0 (Eclipse plugin) generates invalid MBEDTLS_CONFIG_FILE symbol definition for TrueStudio (9.0.0 Windows) project
Double quoted
'mbedtls_config.h' must be inside single quotes:
MBEDTLS_CONFIG_FILE=''mbedtls_config.h''
Otherwise the defined macro will not have double quotes when C preprocessor sees it, causing include statements to fail.
#cube-mx #truestudio2018-01-31 3:15 AM
Hello
Kekkonen.Saku
,Thank you for your report issue.We raise this internally to CubeMx team.
Best Regards,
Imen.
2018-03-13 1:58 AM
Hello
Kekkonen.Saku
,The invalid symbol definition for MBEDTLS_CONFIG_FILE issue is fixed with
version 4.0Bet Regards
Imen
