Bug: CubeMX should warn H7 users against PC2_C/PC3_C pitfalls
2024-08-14 1:12 AM - edited 2024-08-14 1:17 AM
Dear ST,
Users have for years been complaining that Cube is not giving them fair warning regarding speed limitations of PC2_C/PC3_C in STM32H7. Customers are having to respin boards because they fail to notice the fine-print in a 300 pages datasheet.
See Here and Here . I'm sure other examples could be found.
Please make some changes to CubeMX/IDE to protect users against costly respins and time wasted debugging silicon issues.
- Please post an update with details once you've solved your issue. Your experience may help others.
Bug-report
2024-08-14 1:33 AM - edited 2024-08-15 9:03 AM
Hello @BarryWhit
Thank you for this suggestion. I've escalated this internally to the Concerned team to take it in consideration on the coming releases if possible (under internal ticket number 188799).
Best Regards.
STTwo-32
