ā2020-04-20 04:13 AM
I think this page would have the content:
https://wiki.st.com/stm32mcu/wiki/STM32CubeMonitor:How_to_write_a_variable_from_flow
It seems that hashKey value can not be read out somewhere?
{"variablelist":[{"address":"{{flow.current_limit_adr}}","name":"current_limit","type":5,"checked":true,"$$hashKey":"object:604","value":"{{payload}}","validity":true}],"accesspoint":0}
(I know how to use the write panel - but need to set 1 variable with value from flow)
ā2021-11-18 03:32 AM
Hello
I have found some issue in the flow :
Please let me know if it is better now.
Best regards
Stephane
ā2021-11-18 02:51 PM
Hello
effectively the double d was the problem:smirking_face: , I correct the "address" and it works now .
thank you very match for your help, I'm very grateful:smiling_face_with_smiling_eyes:
