2021-10-25 09:32 AM
I am using CubeMonitor for the first time. I would like to know how to save and recall a project.
I can't find how to open a monitor project.
Bertrand
2021-10-26 05:31 AM
you can manage your flows files using project, but it's a bit more tricky:
Projects : Node-RED (nodered.org)
2021-10-26 05:23 AM
Hello @Bertrand
Your project is saved upon deploy button pressed.
If you're working on multiple flows, you can import/export them according to your needs user burger menu on the top right side of the window
2021-10-26 05:27 AM
Ok, import/export is the normal way to do this...I will dol with that.
I was expected open/save. 😉
Bertrand
2021-10-26 05:31 AM
