cubeMonitor project management
Bertrand1
Senior
I am using CubeMonitor for the first time. I would like to know how to save and recall a project.
I can't find how to open a monitor project.
Bertrand
Richard.Chvr
you can manage your flows files using project, but it's a bit more tricky:
Projects : Node-RED (nodered.org)
To give better visibility on the answered topics, please click on Accept as Solution on the reply which solved your issue or answered your question.
3 REPLIES 3
Richard.Chvr
Hello @Bertrand​
Your project is saved upon deploy button pressed.
If you're working on multiple flows, you can import/export them according to your needs user burger menu on the top right side of the window
Bertrand1
Senior
Ok, import/export is the normal way to do this...I will dol with that.
I was expected open/save. ;)
Bertrand
Richard.Chvr
