Good afternoon. Using CubeMX, I created an empty project for the STM32MP157A-DK1 board. It compiles without errors. But when I try to start debugging in engineering mode, I get a message that there are too many breakpoints. When I try to start debugging i
Vlaty.1
Good afternoon. Using CubeMX, I created an empty project for the STM32MP157A-DK1 board. It compiles without errors. But when I try to start debugging in engineering mode, I get a message that there are too many breakpoints. When I try to start debugging in production mode, I have no connection between the board and the debugger. Where did I go wrong? Sincerely, Alexander.
Olivier GALLIEN
Hi @Vlaty.1​ ,
Did you already make a trial with a provided example such as in :
https://wiki.st.com/stm32mpu/wiki/Getting_started/STM32MP1_boards/STM32MP157x-DK2/Develop_on_Arm%C2%AE_Cortex%C2%AE-M4
Hope it help
Olivier
Olivier GALLIEN
Good afternoon, Olivier. Thanks for the help. But I saw a problem with MPU Serial (COM3). I ran ipconfig in Linux and found the real address of usb0 192.168.7.2 after that , the console worked.But the board does not allow debugging. I must have done something wrong. Sincerely, Alexander. �?р, 5 ма�? 2021 г. в 14:43, ST Community :
