why stm32cubeide create a metadata file in the workspace? it's not a good app design.
VictorJee
1.when i once change the workspace path, the ide always create a older folder in last path, and i still don't know why after i checked every config files in application support, preferences, container, also the app package.
2. and what's more, i also use other ide, and use the same workspace folder ( i like),  ***, it also make a .metadata config file,that cause chaos.
1 REPLY 1
Andrew Neil
Evangelist III
That's the way Eclipse works: the Workspace folder is the location of the .metadata folder
Note that your Project files don't need to be in the Workspace folder.
--+---Workspace 1
+---Workspace 2
+--Projects
+-- Project 1
+-- Project 2
