What is the point of this UI element?
capnhyaku
2 REPLIES 2
I realize this post is more a rant than a question seeking a solution, but the point of the element is to include the C++ compiler in the project. Files still need to be named appropriately for it to be treated as a C++ file. If that's not checked, and you have *.cpp files in your project, it won't know what to do with them.
Semer CHERNI
Hello @capnhyaku
First let me thank you for posting.
The STM32CubeMX (the code generator) does not generate C++ code it only generate C code.
However, like @TDK  have mentioned, the this check box is used to include C++ compiler in the project in case your project will contain C++ code.
For example, if you are planning to use TouchGFX for graphics you need to check this box as TouchGFX will generate C++ code.
BR,
Semer.
