2024-04-10 5:17 AM
STMCubeIDE seems to give endless problems. Since the MX can generate c++ code what is the possibility of using all the generated files in C++ Builder? If This is possible, which files should I look for? Has anyone tried this before or will we just have to be stuck with STMCubeIDE.
I do note that many tutorials using STMCubeMX usually have their code generated using other toolchains and not the STMCubeIDE.
Could someone shed some light on this matter?
2024-04-18 3:08 AM
Ok I managed to get STMcubeIDE ver 1.15 to work on Windows 7.
I had to download the zip file from the patch site https://www.st.com/en/embedded-software/stm32cubef4.html
I simply just extracted the zipfile and over wrote the files in the repository on my pc.
No other patches are required
Thank you all
