USBX code not compiling after IDE generation
2024-07-22 8:23 AM
Using STM32 Cube IDE v1.15.1 with package stm32u5-1.5.0 or IDE 1.16.0 with package 1.6.0 (Linux and Windows versions) :
- Create new STM32 project from example Ux_Device_CDC_ACM for board Nucleo-U5A6ZJ-Q
- Compile project : ok
- Slight modification in IOC file just to force code regeneration, for example "Pinout & configuration / Bsp / HMI / USER LED GREEN", save IOC, ALT+K to regenerate code
- Compile : fail :
make: *** No rule to make target '.../Ux_Device_CDC_ACM/Drivers/BSP/STM32U5xx_Nucleo/stm32u5xx_nucleo_usbpd_pwr.c', needed by 'Drivers/BSP/NUCLEO-U5A5ZJ-Q/stm32u5xx_nucleo_usbpd_pwr.o'. Stop.
Some source files have been unexpectedly removed/modified by the regeneration - Undo the modification in IOC, save, regenerate and recompile : still fails (removed/modified files persist).
The complete list of "removed files" by the generation are :
- Drivers/BSP/STM32U5xx_Nucleo/stm32u5xx_nucleo_usbpd_pwr.c + .h
- Drivers/STM32U5xx_HAL_Driver/Inc/stm32u5xx_hal_adc.h + Src/.c
- Drivers/STM32U5xx_HAL_Driver/Inc/stm32u5xx_hal_adc.ex + Src/.c
- Drivers/STM32U5xx_HAL_Driver/Inc/stm32u5xx_hal_ll_adc.h
Modified files (unexpectedly) by the generation :
- Drivers/STM32U5xx_HAL_Driver/Src/stm32u5xx_hal_cortex.c
- USBPD/Target/usbpd_devices_conf.h (removed macros, seems to have no impact)
- Some other minor differences (comments, licenses text files)
The same problem occurs for a personal project in which USBX/UCPD is enabled.
User can fix this problem manually by canceling the unexpected remove/modifs done by (re)generation but it is very annoying to do this each time IOC is modified.
2024-07-22 12:46 PM
Hi @Richard107
This post has been escalated to the ST Online Support Team for additional assistance. We'll contact you directly.
Billy
