USB enumeration issue with Nucleo board acting as USB Host CDC
‎2022-05-06 3:49 AM
I am working on STM32H7532ZIT6 – NUCLEO H753ZI. Trying to connect LTE modem (Quectel EVal board ) via USB I/f using a female connector in between. Programmed STM as USB host at 48MHZ and disabled VBUS. I see that the Enumeration fails as the API USBH_Get_DevDesc. Tried sample code online from several sites and none works
- Labels:
STM32CubeIDE
STM32H7 Series
USB
‎2022-05-10 3:00 AM
Hello @NS.8​,
Welcome to ST Community :smiling_face_with_smiling_eyes:
You can refer to the following example provided under the H7 Firmware Package:
- Projects\STM32H743I-EVAL\Applications\USB_Host\CDC_Standalone
As well, take a look at this video, it may help you.
BeST Regards,
Walid
‎2022-05-19 3:42 AM
Hi Walid,
Thanks for the answer. I am trying to bring the nucleo board STM32H7532ZIT6 – NUCLEO H753ZI as USB host in CDC mode. Can you please let me know whether this board supports CDC mode in USB host?
‎2022-05-19 3:57 AM
Hi Walid,
It will be useful if you can provide USB host examples of STM32H7532ZIT6 – NUCLEO H753ZI so that I can verify the IOC/Configuration file?
Thanks in advance
‎2022-05-19 4:21 AM
Hello @NS.8​ ,
The examples provided under the STM32H7Cube firmware do not have the ioc file.
You can try to customize this example to your needs. This might help you.
BeST Regards,
Walid
‎2022-05-19 11:32 PM
Hi Walid,
I suspect the configuration to be the main culprit in our setup. Is it possible to provide instructions for configuration so that we can verify the same ? WE disabled the VBUS as the module we connect to STM has a separate power
‎2022-05-24 2:28 AM
Hi Walid,
What is the IDE used in this example project?
‎2022-05-24 6:11 AM
Hello @NS.8​ ,
All H7 examples are provided with the following IDEs:
- IAR (EWARM)
- Keil (MDK-ARM)
- System workbench (SW4STM32)
BeST Regards,
Walid
