Update ARM toolchain in STM32Cube IDE
ABern
I wonder if it is possible to add/update manually the toolchain ARM?
Currently it is only 7-2018-q2 while there is the 8-2018-q4 available.
I wanted to use the latest one.
Any ideas?
Thanks in advance,
Kind regards,
Anthony
2 REPLIES 2
ABern
@Markus GIRDLAND​ maybe you could also help me on that one? :)
We don't have support to change toolchains freely yet. However, you might still be able to do it. I haven't tested myself and it's kind of "hackish" to pull off so it's not an official recommendation from ST to do this... BUT:
You could maybe change it in the PATH but that might be tricky since I believe we always put our own first but you might be able to override that.
Or you could try swap the toolchain in the plugin of the CubeIDE installation.
Once again, haven't tried myself and I don't recommend it but if you really want to try that's probably the ways you could do it.
Let me know if you gave it a try and how it worked out!
